Blue Iris UI3
Man, I wish I had just a fraction of your understanding and patience to explain this to people like me :) FWIW, is it safe to assume my 320 install didn't take? I copied the contents of the zip files to the programfiles/blueiris5/www directory and overwrote what was there. But even after restarting the service, and reloading the page, I'm still showing 319 on my browser.
Yes if it shows 319 on the about page, then you didn't put the update in the correct place.
There's no need to restart the Blue Iris service when updating UI3. Just reload the UI3 page.
I am guessing you extracted to the wrong path. Make sure login.htm and ui3.htm go into www, and overwrite everything when prompted.
Ok, it took a lot longer for the stall to happen on 320, but, alas, it did. check out this video of a coyote prowling a turkey... The player delay time seems to float between 80 and 120ms, until about 25 seconds in. Then the image freezes, and the player delay takes off. It eventually starts playing (after 21 seconds of player delay)... Does this provide any more data points?
