I use Home Assistant to monitor the RAM usage on my Proxmox that host Debian VM that runs Docker and runs both ALRP database and CodeProject.
From Home Assistant, I can either restart the entire Debian VM or restart the container using SSH commands.
Do you have any issues where it stops working or ever locks up?
Sure do, I have both CodeProject.AI and ALPR database on the same VM. I can see the VM will run out of RAM in time and then the CodeProject.AI will quit running and/or ALRP database will stop.
The only way I come up with is to restart the docker or VM to make it work again.
I’m running BI6 with built in AI, docker on a brand new windows 11 install and same thing is happening. I can’t figure it out. Every day/two it will lock up
If it's Codeproject.ai that's causing the issues that may be why I'm not seeing anything as I'm utilizing the built-in AI on v6 now.
I'm having the same issue with the built-in (ONNX) AI, so it's not limited to CPAI.
