Hi all,
A few things have piled up over the past several months:
-I moved homes and don't have an active LPR setup to test against yet.
- I changed jobs
- I somehow developed a major endocrine disorder that causes a whole bunch of really gnarly issues, including significant cardiac stress. 167/107 BP when discovered, which is insane. Had no idea that this existed and is something that could just happen. Should be fine and not super relevant as a blocker here, but was a huge WTF.
- This is a good cautionary tale to not minimize or put off dealing with out-of-range results if u get bloodwork done. Had to learn the hard way on this one.
- I took on a project at a university on the east coast running from February through April, which involved a bunch of weekend travel flying back and forth.
- A separate commitment takes up most of my evenings through the end of June.
Ive almost tempted myself to go finish the code a few times as a mode of procrastination avoiding other actual obligations, but this is a single-maintainer open source tool serving a fairly niche audience, and unfortunately does get pushed down the list. The timing with the pending update is pretty shit, and I’d be annoyed if I were expecting it sooner — but there's only one of me, and only so many hours in a day.
@algertc Hows it going? Anything we can do to help?
And if anyone wants to vibe code a pull request and share a short screen recording of it working, I'd be glad to review and get it merged.
Pls post here first if u are someone who wants to try to do this. Will avoid issues later on if I can provide the current progress.
Reactions: iwanttosee
Sorry to hear about your situation!!! You've been a great asset to our little community, so we all wish you well.
I did vibe code two quick fixes to some issues, which I posted here awhile back:
I didn't want to bother you with it at the time, but since you asked, here you go!
This is a good catch on the logging ty. The middleware vulnerability is important, but there is a reason for the sidecar that was dropped. I have this sort of swapped for a different system in my code currently which will allow for other drop in things like adding another container to the compose to run a tiny model for semantic search.
Can’t quite merge this directly in with the commit it has, but I will use the logging fix. Thank you.
Reactions: TheWaterbug
It was all Claude! I was just watching. It was actually funny; Claude was soooo convinced that 100% of my performance issues were because of this logging thing, and then when it found the malware it actually put exclamation points on its response put its response in ALL CAPS:
The Node.js process is healthy per stats.ndjson — but 125 PIDs vs 23 is suspicious. Something is spawning many processes. Let me see what's actually running.
Ran: List all container processes sorted by CPU
STOP EVERYTHING — this is malware, not a memory leak.
PID 70 (/v0UDjR -c /b27pyQ -B) is running at 406% CPU and 2.4 GiB RAM with an obfuscated binary name at the filesystem root. The -c config -B flags are the exact invocation pattern of XMRig, a Monero cryptocurrency miner. The dozen zombie [let] and [BcXsGyx] processes are its spawn history.
The miner is what's been pegging your CPU and RAM, not the Node.js app. The pkill -f sh is the miner's anti-debugging self-defense — it kills shell processes to evict debuggers. We've been restarting a compromised container repeatedly.
I’m not sure if any of you follow any tech news of this sort, but dependency supply chain attacks have been absolutely rampant hitting huge companies left and right recently.
Grateful for good maintainers and researchers that are finding things quickly now, but this is definitely an important reason to update. Someone else read through this and said something about a crypto miner? I didn’t find that post, but if you could tell me what package it was, I’ll be sure to double verify along with the regular dependency wide security scan.
I was having performance issues as well to the point of the machine running the app shutting down. Would make much more sense if this was the issue.
Package was Next.js 15.0.3,
I'm running out of space on my Linux VM for ALPR. Only have a few hundred Mb left.
Is there a way to delete some of the older storage images in ALPR? I tried to manually delete them in Linux, but I can't. I tried downsizing my database image retention but that doesnt seem to delete the images.
I was going to increase the VM disc allocation using Gparted, but I dont have enough space to download it.
EDIT: I wasn't being patient enough. Records were pruned after awhile by reducing image retention time.
Reactions: algertc
I'm also wondering if there is something we could do to help with either fixing issues in the existing repository, or working with @algertc to speed up development of the next version of ALPR Database that he was working on. I'd love to help but I've been out of active development for awhile. Maybe a training session with algertc where he could explain his existing set-up, development tools, what it would take for others to contribute, etc. While Charlie has been instrumental in doing all the work so far, it does put everthing on his shoulders to handle all the numerous requests that are coming his way and I'm sure he only has a limited amount of bandwidth/interest to do it all himself. Personally, I could continue with the existing ALPR DB if it had a few updates (table of auto correct rules, notification rules, and better authorization/keep alive).
Just today I tried my hands at using AI to fiddle with the code. Not having much luck as this is a big learning curve for me. It was suggested to implement security fixes first then go on from there. Will update if I have any success. I did this because it is becoming clear that the project has become abandoned.
I got this working today well with 5 LPR cameras I have set up around my neighborhood. However I am unable to create tags. When I try to these are the errors I am seeing in the Docker console. It is complaining about a null value in the id field. Anyone able to help me fix this?:
Fetching tags
POST /database/tags
Middleware checking path: /database/tags, Session ID from cookie: fedac613c8d83b2590c61a832e6bc394b7a6adec272120ed2b9b7befb07d391a
POST /api/verify-session
GET /api/check-update
Adding tag
Error creating tag: error: null value in column "id" of relation "tags" violates not-null constraint
at <unknown> (/app/node_modules/pg-pool/index.js:45:11)
at async T (/app/.next/server/chunks/9368.js:312:187)
at async F (/app/.next/server/chunks/9368.js:1:6686)
at async (/app/node_modules/next/dist/compiled/next-server/app-page.runtime.prod.js:127:1299)
at async rc (/app/node_modules/next/dist/compiled/next-server/app-page.runtime.prod.js:126:11937)
at async an (/app/node_modules/next/dist/compiled/next-server/app-page.runtime.prod.js:132:1048)
at async doRender (/app/node_modules/next/dist/server/base-server.js:1568:34)
at async responseGenerator (/app/node_modules/next/dist/server/base-server.js:1814:28)
at async NextNodeServer.renderToResponseWithComponentsImpl (/app/node_modules/next/dist/server/base-server.js:1824:28) {
length: 234,
severity: 'ERROR',
code: '23502',
detail: 'Failing row contains (null, Resident, #22c55e, 2026-08-08 07:37:35.012777-04).',
hint: undefined,
position: undefined,
internalPosition: undefined,
internalQuery: undefined,
where: undefined,
schema: 'public',
table: 'tags',
Fetching tags
POST /database/tags
Adding tag
length: 234,
severity: 'ERROR',
code: '23502',
hint: undefined,
where: undefined,
schema: 'public',
table: 'tags',
Somehow part of your database schema didn't get updated to the latest version. Try manually reapplying the schema.sql and migrations.sql.
  • Grab the updated schema.sql and migrations.sql directly from the ALPR-Database GitHub Repository.
    Move the fresh files into your local host directory mapped to the container.
    Access your database container console and run:
    psql -U postgres -d postgres -f /migrations/migrations.sql
