Spent a little more time testing with some added motion ambient light. If I run the shutter to low once the motion light comes on, I lose the sidewalk area. Tonight, I just tried 2 different settings as it is windy and wet outside.
settings:
settings:
Get the NR down below 25 and see how it looks, maybe even below 20 if you can. Shutter still too high on manual settings, needs to be 0-6ms or less, ideally 0-4, also lowering gain will help. Getting the porch and street will be a struggle in colour with different lighting, stick with IR for that situation as mentioned above. Just try dropping the NR down to say 10-15 for experimentation, NR is really impacting mine, I've got NR off during the day, and below 20 with IR and LED, 18 and 19 from memory. You can even try reducing sharpening to say 25, again, to test, I have really been pushing the limits in low light and ultimately end up with low NR, low sharpening and very fast shutter. Don't be shy with the fps either, even if you only need 10-15, worth trying 20fps and keep the bitrate high, above 10000kb.
