My 4K-T works fantastic. I am using the G-711A and the mic is very hot but quite manageable and crisp.
Yep exactly. If you do bump to AAC you’ll hear the crispness further and a little more depth. Either way, the cam does a good job of pickup and certainly hotter than the 4K-X at same settings.My 4K-T works fantastic. I am using the G-711A and the mic is very hot but quite manageable and crisp.
Replying to myself here with an update for all. I've completed thorough testing again across 3 different browsers Safari + Firefox (on Mac) + IE (on PC). I specifically went through each scenario people have reported, noted below for reference:
In each of these, I can state (and also show in this video) that they are not happening in my testing. The cameras are working correctly and as expected in each of these scenarios in my tests again today. I went back into each camera (the 3x 4K-T's I have) and tested. For reference, the camera that I recorded the footage against for the test in the video is a production (not beta, not pre-production) 2.8mm unit that Andy has been shipping out to all.
- Schedule not changing in Live View mode
- Settings not 'sticking' after being applied
- IVS rules being impacted (creation / adjustment)
- IVS rule resetting Exposure when clicking Apply
- Play back not working in browser for recorded clips from SD card
With the exception of the Mac based bugs for Safari and Firefox that I filed with Dahua when I first started testing these cams (applies to all 5.0 GUI cams on Mac), no issues are seen. Those bugs for reference are that Image Adjustment (for viewing parameter adjustments on Live Mode such as adjust contrast of the image for Live mode screen only) + on screen graphic functions such as E/PTZ creation (A180 cam) do not work with the embedded plugin and prompt you to download a Windows plugin ! This bug for Mac will stop IVS and E-PTZ graphics even being saved (you won’t even have an option to apply them as it will error out) BUT again this is ONLY for Safari & Firefox on Mac. This is NOT an issue for Firefox on PC as well as NOT an issue for IE as I show. So with that stated for continued reference, as you'll see on the video (11 mins but wanted to be complete), all the above scenarios tested fine.
Video being uploaded now and will update as soon as available thanks to the usual YouTube re-encode dance.
Almost forgot, didn’t show in this video as it was already 11 minutes in length BUT I did also test on Chrome on PC (v106.0.5249.119) as well as Firefox on PC (v102.3.0) and both of these are also working fine too in each of the 4 areas above. If people do want to see this as well, I can always capture more footage.
HTH show what I’m seeing across 1 x pre-production and 2 x production line 4K-T’s and critically that these issues are not present in this testing.
UPDATE - YouTube finally is ready in 1080p HD (make sure you manually select), still awaiting the YouTube 4K re-transcode (rant: wouldn't mind but the 4K file I upload already meets their standard requirements for encoding !, rant over)
Here is the video of the testing and the results
Additional Notes
- Timestamps added for each browser test + intro at start mentions versions used in the test
- At 07:47 of the video I mention setting night to 12:18:01 but my note I add shows 12:12:01, that was a Wildcat slip-up in the note, the actual time set as you can see on video is 12:18:01. You’ll also see the Windows Not Genuine popup when I have a fully licensed machine, gotta love Microsoft and one of many reasons why I moved to Mac
- Also while I show it on screen in the Safari on Mac test, I didn’t call out specifically (so doing it here) that exposure settings etc never changed when applying IVS rules. Just calling it out more clearly here so people saw that it wasn’t an issue in this test either.
For reference, my testing are through managed POE switches@EMPIRETECANDY I did some more testing this morning. Can you tell me if you are using a PoE switch or power supply to power the cameras?
I am dead serious about maybe two in those windows. I had never thought about putting a 4K-T up there until your post. You know I have light there. See the still from tonight for the SD12203T-GN.@samplenhold yeah lol I am torn between the mini PTZ and another 4K-T myself LOL. I am leaning towards the 4K-T as I don't have the light for the mini PTZ MP/sensor combo. Or maybe both like you LOL.
So now I have the Dahua 4K-T 2.8mm on top and the competing Hikvision DS-2CD2387G2-LSU/SL 2.8mm right underneath it mounted about 7 1/2' high out front. This is definitely producing a lot of looks for people walking by, especially with a gigantic ladder out front with various object placed on different rungs.
@samplenhold Totally agree with Rule #1 now!
There is all sorts of quirks with and variations between these two cameras. I've spent the last couple of hours fighting with the image adjustment controls to get as close to a similar image as possible. I've been testing at night here with street lights, I manually set the shutter to 1/30 on both cameras. For both cameras, the WDR washes out colors. For both cameras, HLC produces the best image for me with both bright areas and dark areas, but I had to turn down the exposure compensation on the Dahua. Without HLC, the text on the box would be super overexposed, or after adjusting image settings the background very underexposed.. Overall I was able to produce a noticeably better night image on the Hikvision.
I also compared the microphone as I was having trouble with all the digital noise in the Dahua 4K-T. The Hikvision actually has some very noticeable background static, but nothing like the noise I was hearing from the Dahua. The microphone is definitely better in the Hikvision, and the Hikvision also adds a built in speaker. They're both not what I would call high quality audio though by any means.
Regarding the focus, I put a box with various sizes and colors of text on it out about 7' high on a ladder. Although the Hikvision DS-2CD2387G2-LSU/SL specs show a 4m to infinity depth of field, the Hikvision's close focus is quite noticeably better than the Dahua 4K-T's.
Anyhow, I think the right thing to do here would be to start a new thread for a comparison of the Dahua Color 4K-T and Hikvision DS-2CD2387G2. To be continued...
