flynreelow
- Dec 12, 2016
- 1,531
- 1,406
andy really is the man. great customer service.Andy is a wizard. I'm not sure how he did it, but I just had a very good conversation with him and he has restored my faith in his brand. Not only has he convinced me to keep my existing camera, but he has also convinced me to buy another one. LOL
After some further talking with @BadKarma i am happy to get a happy client again, all issues sorted, though he left a bad review on aliexpress, but that is not important.
He is going to buy one more camera IPC-Color4k-T 2.8mm black, lol. Thanks all guys' support and help.
Yes, he will try his best if he can revise it, and he bought a black IPC-Color4K-T and will leave a real feedbackHopefully he goes back and amends his 1 star review....
First, this thread has been really helpful and I'm sure it will help a lot of people that don't post here as well. Everything is on-point to help people understand the pros, cons, and issues with this camera, as well as help people decide what other options are if the specs and price of this camera work for you.
After testing this camera for several days, I've got some issues to add and things to point out.
Still working on - potential issues
1. I just tested the microphone in this camera, and with very little ambient noise around, all I hear are mostly loud tinny sounding digital beeping noises. I've tried disabling noise reduction, but that does not work. I've attached an audio extraction below. Is this defective?
2. When using this camera directly with the DMSS app, I'm not seeing IVS rules that I create in the push notifications configuration. Push notifications are only configurable with the default IPC. I created 2 intrusion IVS rules, and they don't show under the intrusion section of the push notification configuration, only IPC does.
3. I don't see a way to disable or at least lenghen the web interface session timeout to prevent it from logging you out automatically.
Issues
1. The depth of focus is definitely an issue and great efforts should be made to SET EXPECTATIONS AHEAD OF TIME so that this is known to anyone prior to purchasing this camera. There will be a ton of detail in the near range sacrificed for the low light capabilities. This is important to anyone using this camera to monitor property within 15' of the camera.
2. Dahua does not support a + sign in an email address, both in the camera, or in their app when signing up.
The dot we explain here, not a hardware problem, all cams have it at dark place, just the 4K with the 1/1.2cmos can find it when you enlarge the pics with digital zoom, not really effect the pics quality. Color pic at dark place the cam auto increase the light gain , so white dots comes at dark area. If you want it work as daytime pic, just increase more light in the light. But for security purpose this cam build in led is good enough. If you want a dream full color cam without any external light, none of these cams can work for you.Considering the 4k-t. Does the 4K-x have the dots as well?
Yes, I also test the hikvision 4k 1/1.2CMOS turret too DS-2CD2087G2-LU 2.8MM
Right now daytime here, but i also find the dot too when digital zoom it a little. Will post more pics later at night.
Yes, agreed. As I mentioned earlier, this is part of the algorithm related processingHaving seen these now, I don't believe they're hot pixels. Look more like gain artefacts. The fact they disappear with more ambient light suggests very much to me they're gain related. Probably the price to pay for amplifying the light so much to enable this camera to see so well in the dark.
