Worlds First Review - Dahua DH-IPC-HDW5849H-ASE-LED / IPC-Color4K-T - 2.8mm Turret
Wow, that is some reply, thank you kindly. Oddly that last video looks soft focused in the background, where as the others are tack sharp, assume the same camera. Looks like I will be ordering a bullet or two in 3.6mm, loving these 4K series cameras, these samples show all you need to know :clap: :thumb:
Bright sunlight and a bit overexposed I think. along with serious shadows
Do you feel that by 18-20 feet the 3.6mm is beginning to move outside of it's optimum focus window, watching this again and looking at stills, almost seems like it is sharper between 12-15 feet. I am now totally confused whether to go with 2.8 bullet or the 3.6mm, maybe should just get both and see if the 3.6mm works OK, the two locations I have in mind are both essentially around the same distance, classic case of wanting everything sharp and in focus but requiring a touch more reach! The low light abilities on these is frankly enough of a benefit for me to sacrifice reach. I guess ideally focal length would be around 6-8mm for my application but this is no use if the camera cannot work well in low light/night conditions, this is where the 4K series are winning for me.
Reactions: JDreaming
I could argue that past 20-25ft ANY 3.6mm is beginning to lose optimal focus and detail.
But I haven't played with a 2.8 so can't compare
Both are ultimately going to be an overview cam, though I enjoy it as an ID cam in my location from 6-12ft
With the 3.6mm bullet, what is the real world minimum focus distance as a rough guide. I have a distance to target of between 16-20 feet, am hoping the 3.6mm will work well for that. I have a couple of the 2.8mm turrets, the benefit of the close and near LED's on the bullet will be useful for me, are there any downsides for those who have both vs the turret?
Years ago I decided to actually measure the resolution of some Color4k-X cameras versus distance. The graph below shows my results.
The resolution is measured by noting the finest bar pattern that can be seen with the proper number of bars. The distance is measured from the front of the bullet camera. The target is a modified 191 USAF bar target printed out on card stock. I have only one camera with a 2.8 mm focal length lens but two each of 3.6 and 6 mm.
I find that both the 2.8 mm and 3.6 mm have the best resolution of around 1 mm around 4-6 feet from the camera. I was very disappointed in the performance of the 6 mm and would not use it until the subject distance is greater than about 20 feet. All cameras came close to their theoretical resolution at large distances. At short distances the defocus caused a rapid loss of resolution.
Wow, that is a lot of work but very interesting. This agrees with my findings based on user feedback and my own experience with the 2.8 at least, sharpness is good from 5-12 or even 5-15 but then falls away from there. I mean they are still insanely good past those distances frankly but this does make sense. The 6mm really not putting in a good show. I will be getting some more of these cameras, they are way too good in poor lighting. On a side note, you have quite a number of cameras listed there :wow: :wow: 20 by my count! and you like the 4K's which I can understand.
Looking back at my graph the curves are pretty much as I would expect. The Color4k-X 2.8 mm camera has a best resolution at around 4 feet. The hyperfocal distance increases with the square of the lens focal length. Thus the 3.6 mm version should have a best focus of 6.6 feet and the 6 mm at 18.4 feet. This agrees with the graph.
If a camera is focused at the hyperlocal distance the at half the hyperlocal distance and infinity will have the same circle of confusion in the image. Everything in-between will be better. This concept is used in photography to maximize the depth of field while also imaging distant object. It looks like Dahua used a circle of confusion barely larger than the size of a pixel.
Not all of the cameras I list are currently in use, but I do have way more than needed. I think I may be an addict.
What shutter speed are most running on these in medium to poor lighting? I've been on 2 or 3ms but on closer inspection think I need to drop it lower, like below 1.5ms. I am relatively new to the 4K and of course the 54Pro, seems they all like to be running at much faster shutter speeds than the S3 and previous 5442's
Run it as fast as you can before the image with motion is degraded.
We all reach a point with this camera that we get a rolling shutter type effect as the camera tries to overcompensate for not enough light.
I am currently running on the original shipped firmware V3.140.0000000.32.R, Build Date: 2025-01-15, just wondering if there is any major real world benefits in upgrading to latest release which is a few versions newer. They list some 'bug' fixes and other features, normally I am a 'if it aint broke' advocate but also realise there could be some things broken that I am not fully aware of ;)
I like to try out various fixed shutter speeds during the daytime with lots of light. I look to see what types of motion blur at the various speeds. People and cars, fast and slow, head on or transverse. There is usually enough day light that I can set the daytime shutter speeds to 0-X mS so that all motion is frozen. I find this especially important for setting my license plate readers.
Nighttime settings are always a compromise. But by looking at the daytime blur at slower shutter speeds I can balance motion blur with noise.
I have dropped one of mine down to 0-0.9ms during the day with 20 gain and 0-2.7ms at night, the latter with 50 gain. It could be just like digital cameras, higher resolution requires somewhat faster shutter. Also finding that keeping gain low helps keep the quality up, more so than the 4mp cameras I have. Still loving these though, my most capable camera for both day and night, never fail to capture something useful whether it be detail or colour.
