Review-SD4A425DB-HNY 1/2.8" CMOS 4MP 25x Starlight Auto-tracking MiniPTZ
I own one of these. But be warned, it is pretty loud when PTZ functions are working. There is an alternative model, that is much quieter, and uses undetectable (to the human eye) IR.
And, your are right, no real activity from Dahua on cameras in this category. I really can't see a reason why Dahua hasn't made available this size/type of PTZ with a 1/1.8 sensor. That would be a killer camera.
It’s noticeably loud? Do you have an example you can share?
It isn't. But like everything, it is relative.
Do a search in this thread on "noise" and you will see what others have said about it.
It sounds a bit like R2D2 and in the middle of the night with no other sound, someone may slightly hear it.
But middle of the day I don't hear it.
Ok thanks for the info.
Is there any other noticeable difference between the 2 models besides the quieter motor?
The 'quieter' camera uses different wavelength IR at night. So no red LED's are visible by a human on this camera. The downside is, if you use supplemental IR or have cameras in the same area, their IR won't be seen by the 'quieter' camera.
Reactions: flynreelow
What wavelength is the SD4A425DB-HNY-R? It looks like it just has a dark tint applied to it to make it "invisible" so I'm curious if it really is a different wavelength at all?
It says 'invisible' for IR on the camera specs. That would be 940nm versus 850nm normally used on almost all security/surveillance cameras. So it truely does have more than just a smoked cover as to detect 940nm IR you would need a different filter also.
I think "invisible IR' is a marketing term not a technical one.
if it truly was 940nm it would say so in the specs I would think
Reactions: TuckNTruck
I think "invisible IR' is marketing term not a technical one.
You could be right, on this. But the specs for both cameras show an IR distance of 100m vs 50m for the invisible. According to AI that's about the max distance for 940nm IR. Who the fuck knows for sure. Even the official spec sheet from Dahua only says invisible for IR, with a max distance of 50m. We all know how accurate a Dahua spec sheet can be.
I have this camera and have just ordered another. It is great and suits my needs well.
The motor is audible when in operation as others have said. In my opinion that’s not really a hindrance unless your are operating in stealth or have it moving around loads at 2am while mounted above a bedroom.
How does the picture seem at night to you? Can you provide a video or picture?
The dark tint model (same sensor and IR wavelength ) is noticeably darker at night.
It’s not great at night to begin with due to low powered IR. No sense in making it worse with the dark cover.
