Yes, that is on my list for the day, but a port cannot cause an 18-20 second delay in video, that is a LOT of data in a buffer, and a switch just doesn't have the ability.try another port for shits
Yeah somethings fucked up.
Any chance the port was previously configured to a 802.3af budget?
WS-C2960L-24PS#conf t
Enter configuration commands, one per line. End with CNTL/Z.
WS-C2960L-24PS(config)#int gi0/8
WS-C2960L-24PS(config-if)#power inline consumption 25000
WS-C2960L-24PS(config-if)#^Z
WS-C2960L-24PS#sh power inline gi0/8
Available:195.0(w) Used:123.9(w) Remaining:71.1(w)
Interface Admin Oper Power Device Class Max
(Watts)
Gi0/8 auto on 25.0 Ieee PD 4 30.0
Interface AdminPowerMax AdminConsumption
(Watts) (Watts)
Gi0/8 30.0 25.0
WS-C2960L-24PS#
Interestingly, the delay is down to 7-8 seconds.... but that still seems like a lot... AND the clock on the camera in BI only updates every 5 seconds... That does nto seem to be normal..
BINGO.... initially during the PoE problem I was local, but to continue troubleshooting from home, I used RDP... and this feature added to the problem... I have changed to unrestricted. Thank you so much!!!How are you viewing the camera in BI, directly via the console or remotely? Check under BI Settings > Cameras > Video during Remote Desktop and set to Unrestricted.
I am having the EXACT same issue.recently mine started losing its PTZ preset. I have the preset set for my driveway but I will find my camera looking at some random position. moving the PTZ control to look at another position and hitting the preset for driveway will point it back in the random position i found it. Could this be a belt slipping and the camera "thinks" in in the right position?
It is almost as if it learns a new 0 and each preset is offset by that distance. I have found rebooting it through the GUI will fix it, but it has randomly lost 0 more than once.
You two using BI?
What firmware are you on?
I haven't had any problems with this at all. Perhaps a setting.
Perhaps an issue with BI? I'm using a Dahua nvr and smooth sailing so far.
I've had this happen too where it seems it has a new 0 position, but after a short while it reset itself to the right position.
Another issue I'm having: when using DMSS or SmartPSS to move the PTZ manually, it will sometimes be stuck in a command and just keep on turning around and around. Can only stop it by rebooting, it won't react to other commands or a preset command.
Is this something found with other PTZ's?
I would tend to agree. I had the same behavior in BI as I did in the GUI.my guess is that it has nothing to do with Blue Iris. the preset behavior acts the same on the cameras web control as with BI
Yea in SmartPSS that works. In DMSS I can close the app completely but when I re-open it the cam is still spinning.I found all you have to do is close SmartPSS and it typically stops.
