I purchased 2 from Andy. Both working well so farYou two using BI?
What firmware are you on?
I haven't had any problems with this at all. Perhaps a setting.
Any update BRF? Would like your thoughts on this one.Well I bought one of these from Andy's Amazon store. Wont get it installed for a couple of weeks but hoping it will solve a problem and help me save adding two more cameras.
Will post up results here
I am giving serious consideration to using this cam to replace three overview cams mounted in the second story windows. Two are SD12203T-GN cams and the third is a fixed lens dome that is five years old.
The 12203 do quite well being 2MP on the 1/2.8" sensors, so I am a little hesitant on this miniptz being 4MP on a 1/2.8" sensor. But I am intrigued with the auto tracking and the longer optical zoom. Since they are in windows they cannot use cam IR and I really want them in color anyway.
Depending on your views and if @EMPIRETECANDY has a good price on the Memorial Day sale, I might just pick one up to try out in those positions and see how it performs for my use cases.
Actually as close to the street as it is and with most everyone here older and retired, I expect a lot of "WTF are you taking my picture for?" comments![]()
One of the main reason I'm considering buying this SD4A425DB-HNY mini ptz is because of the dome design make it difficult to see where the ptz is pointing at unless people get really close to it. I bought the Hikvision mini ptz a few years back for the same reason even though I'm aware of the dome camera shortcomings.![]()
I wish there was a way to adjust the sensitivity or movement of the camera once it detects/get triggered.
Please see attached video.
That moment when the camera detected an object/target and start the tracking process, that same moment was when I believe (In my opinion) the right frame to see the face.
Unfortunately because of the sudden movement, it got blurry. lol (Around 4 second mark in the video)
Maybe a firmware update to fix this or a feature request? @EMPIRETECANDY
Thanks
Try a tighter initial zoom and increase the track size target.
This is also where spotter cams can help as it could turn the PTZ to the right and start tracking them before they are on your property so that it is the optimal zoom and focus by the time they are the closest to the camera.
