Do you have an NVR with or without PoE?
Without Poe. It’s the 5216-4KS2
Lights using button on iPhone should just work.
Audio needs to be enabled on the camera
Camera/Audio/Enable main stream
You may have some funky setting like the Disarm feature enabled?
On camera - Event/ once click disarm can be enabled, but don’t enable “Disarm by Period”
Just checked and the settings you mentioned were already set at is.
Edit: not sure why I can't post an attachment but take my word for it, those settings were as you mentioned.
It has been noted in several threads here that for some reason we can't attach photos, which is unfortunate as they tell so much and help tremendously with troubleshooting!
I expect as you have suggested. That your NVR on the old firmware, is not capable of dealing with a camera with the features that are not functioning. Perhaps update the firmware if possible?Do these commands run thru the NVR? My firmware is old and hasn’t been updated. Really don’t know if that would matter in this situation?
My NVR 16 channel (5216-4KS2) is a non POE version so my cameras are all on switches.
That unit is EOL but that’s fine,
Last FW was Oct 2024 which is good
Make sure it’s your model
Drop down menu Firmware
I'm sure the respected. "Bigredfish" has verified the link he provided is valid, to be appropriate.Does it matter if I grab the firmware from the link you provided or from EmpireTech’s website?
V4.002.0000000.8.R.241030 should be the right firmware.Does it matter if I grab the firmware from the link you provided or from EmpireTech’s website?
