Tried increasing on sub2, but didn't help at allBitrates are way too low
Better use H264H. Why do you need 2 substreams?Tried increasing on sub2, but didn't help at all
same results, output quality doesn't change at all.Better use H264H. Why do you need 2 substreams?
Possibly.
First try with H264H at max bitrate (that will stand a better chance than H265 for that field of view) with no other options like MD or IVs enabled and see if you can pull adequate substreams. If you can then try adding IVS.
I am trying to configure the 6MP version of the Color4M-T camera, but I am having an issue with the combination of IVS and Smart Illumination. When I use MD with area masks and SMD, it is possible to constrain Smart Illumination to a specific area. However, when I enable IVS, Smart Illumination works across the entire scene. I need to partially disable Smart Illumination when IVS is active. Is this possible?
I have just made a test and MD masks work with SI. (SMD set on too). IVS disabled. Camera - 3649H AS PV Pro.
Wild
So unlike the AS fixed lens version, the 3449H ZAS-PV-PRO does NOT activate white LEDs solely by having Smart Illum set with NO IVS.
When IVS is enabled, only then will Smart Illum turn on the white LEDs. IVS seems to be a must for the white LED's to activate.
On the other hand, I've shown clearly before that the fixed AS version will indeed turn on white LED's using only Smart Illum. No IVS required.
Different FW
ZAS - V3.140.0000000.16.R, Build Date: 2025-06-20
AS- V3.140.0000000.7.R, Build Date: 2024-10-18
Like the 5442's, BOTH cameras dim IR LED's when IVS is enabled. A Lot!
Fixed Lens
View attachment 233118 View attachment 233115
ZE varifocal
View attachment 233117 View attachment 233116
