these are upclose pic of my doorways. do you recommend the 3449 Pro for all of them ?3.6 in most cases. Especially at your doorways. You do have cameras planned for your doorways right?
this is the view from the spot where i'd put the LPR camera looking in both directions, except they'd be higher at 2.5MYou’ll have to look at direction and angle. Maybe. Generally you don’t want more than 30 degree angle. So think in terms of the target area being 50-100 ft from the camera to get a reasonably straight shot.
The Z12 is the go to camera for this. Andy will know what that is.
And you’ll need 2, one for each direction, they don’t move
didn't even think of that - but yes they can definitely disappear!Some of those little tree's may have to magically disappear in the middle of the night but yeah looks close
empiretech01.com
empiretech01.com
empiretech01.com
empiretech01.com
empiretech01.com
empiretech01.com
empiretech01.com
The only consideration would be stepping up on the NVR the next level but it’s another $250
The advantage is more bandwidth and the ability to run VMD on the recorder while your cameras run IVS. So if money isn’t an issue I’d do that. If budget is stretched don’t worry about it. 90% of folks probably would say it’s not worth it.
@steve1225 your opinion on the upgrade NVR?
EmpireTech NVR16CH-16P-2XI 16CH 1U 16POE 2HDDs Network Video Recorder
Max. decoding capability: 32 × 1080p@30 fps Max. 512/512/512 Mbps incoming/recording/outgoing bandwidth Supports IP cameras with a resolution of up to 32 MP Supports AcuPick with up to 16 channels AI by Recorder AI by Camera Supports N+M cluster, ISCSI Supports EPTZ, and one-click arming and...empiretech01.com
I heard that turret cameras don’t require the mounting junction box. They can be mounted on walls and eaves and look much neater on a house that way. But I’m unsure how true this is ?I think you’re good to start.
I prefer 3.6mm at doors
Most all of those have a junction box you can /should purchase. Andy knows which ones
You’ll need 2 Z-12’s for LPR both ways
Can I just use a 3449 pro 3.6mm at the garage/driveway as well? It’s a few bucks cheaper than a 5442 varifocal.I think you’re good to start.
I would stay with the 5442 VF. You dont really know what focus point you need exactly
I completed my purchase with andy and went for the upgraded NVR.The only consideration would be stepping up on the NVR the next level but it’s another $250
