EmpireTech NVR / 5442 S3 Cams - Webplugin Not Functioning in Edge Browser
Except I updated to the latest firmware, remember? Then we tried rolling it back.
I guess. I just think a year later we’d have seen it before.
I suppose you could default the NVR using the button in the GUI. Really all you lose is the time setup, networking if diff from default, and the record schedule.
Just don’t tell it to default the cameras
+1 above.
Best practice is to factory reset a device before a firmware update and factory reset after the update.
And folks that get under the hood have seen a firmware update not completely take until a couple of factory resets.
So many of us adopted 3 factory resets before and after the firmware update.
So perhaps your bouncing back and forth firmware has something corrupt behind the scenes.
Reactions: JDreaming
+1 above.
Ahhhh Interesting. Not a bad idea.
+1 above.
So that looks like it totally wipes it out, Network and all, correct?
+1 above.
Okay, so a factory reset will totally wipe everything out, right?
Yeah it wipes it out - one of the many other reasons why many prescribe here to the "if it an't broke, don't fix it" mentality and do not update a system that is working for us and only update IF the release notes confirm it fixes a problem we have AND doesn't break or remove something that we use.
But on the NVR its just really the 3 things I mentioned which should take 15 min to reset? What am I missing?
...all you lose is the time setup, networking if diff from default, and the record schedule.
Assuming youre not doing AI functions by recorder, which on that NVR you aren't
^True. We make it much worse in our head than it is.
It sucks to have to set it up again from scratch, but even PTZs aren't that bad if you screenshot everything before hand and then just recreate it.
Same with an NVR.
Yeah I'll do a reset on an NVR all day vs trying to get my IVS rules and all my image settings back to right on a camera.
I do the same and take snapshots of everything but damned if I dont miss one or two!
That seems to have fixed it. Video and controls are both back. I didn't realize that if I just hooked a keyboard and monitor up, I didn't have to F with all of the web browser mess. I may just leave it down here by my desk.
I have tried it with no success.
Here are the full instruction how to:
How to enable native Internet Explorer in Windows 10 and 11:
  • Open Notepad:
    • Copy then paste the single line of code below into Notepad:
    • CreateObject("InternetExplorer.Application").Visible=true
    • Save as OpenIE.vbs
  • Make sure the the file name ends in .vbs not .txt, If it ends in .txt you must rename to .vbs
  • Create a shortcut to the above file and double-click it anytime you want native Internet Explorer.
Awesome.
Something along the way got confused. On an NVR it isnt common but shit happens.
Glad you're back up and running
  • Open Notepad:
Yes, as I said, I tried it. Look a couple responses up and you will see it took a full factory reset to fix it. It's all up and going now.
Reactions: Jahua95
