alekk
Getting comfortable
For those interested, here's the "version numbers" that change when you push to the latest firmware from @EMPIRETECANDY - changes in BOLD.
I applied the (smaller - 123MByte) "IPC" file first and then the (746MByte) firmware.bin second. The camera rebooted each time. After that (per comment from Andy) I did a Maintenance Center->Maintenance->Default->Default (NOT Factory Default) which resets most everything except "network, user management, and so on" ... and then reconfigured the camera. LOL a "good test" of your setup procedure! ;-)
As others have mentioned, there is a new option under Camera->Exposure->AI-ISP which you can toggle on/off ... which I think is the "magic" button to disable some of the "wizardy"
I haven't looked "enough" to say if it's better/worse ... just letting folks know the upgrade was easy to apply and appears to be working fine.
BTW, kinda interesting that the "System Version" for Andy's firmware is ".5.T" dated 2025-11-27 ... whereas the Dahua firmware (which I have NOT tested) is "4.R" dated 2025-11-11.
2025_10_28 Firmware
ONVIF Version: 25.06(V3.1.0.2298085)
System Version: V3.146.0000000.0.R, Build Date: 2025-10-28
Web Version: V5.01.0.2340775
Algorithm Version: V5.10.20.1
Security Baseline Version: V2.4
H5Player Version: V3.01.1
Cloud Service Version: 2327855
Face Detection: R1482440.0_V3.005.0000000.0.R
People Counting: R1486745.0_V3.006.0000036.0.R
Video Metadata: R1489959.0_V2.010.0000000.7.R
Heat Map: R1486745.0_V3.006.0000036.0.R
IVS: R1515312.0_V2.010.0000000.0.R
AcuPick (Motor Vehicle): 1007001000004
AcuPick (Human Body): 1005001001004
2025_11_27 Firmware
System Version: V3.146.0000000.5.T, Build Date: 2025-11-27
Web Version: V5.0001.0.251126.2360417.2361663
Algorithm Version: V5.11.10.0
Cloud Service Version: 2348018
Video Metadata: R1519389.0_V2.010.0000000.12.R
Smart Object Detection: R1515332.0_V1.005.0000000.0.R [NEW]
2025_10_28 Firmware
2025_11_27 Firmware
