So this morning, we have an image taken from a T54PRO-ZE using some brand-spanking new 1028 Firmware that
@EMPIRETECANDY just sent me - thanks!
The upgrade was seamless (had to do by file rather than by folder ... but just did one at a time and it reboots after each) and below are the version number changes (BOLDED) from Maintenance Center->System Info->Device Info.
I don't see any difference at first glance (download of .dav files is still about 1.3MBYTES/sec even though the Firmware loaded at about 11 MBYTES/sec) but I'll be futzing around with it. The only "issue" is that with the "Skull Brothers" now in the picture, the auto-focus tends to snap to them (which is to be expected!) but simple enough to use Area Focus. Settings are 5msec shutter, 100 iris, 0 gain, 0 NR, everything else "default" but Sharpness push from 50 to 75.
I did this on my "lower" camera - the "upper" T54 is still running 0827 ... but I'm thinking I might push that to 1022 so I can more easily see if 1028 changes anything.
@EMPIRETECANDY : I didn't see any change/release notes - anything you can share that we should look for with this latest release?
1022 Firmware
ONVIF Version: 25.06(V3.1.0.2298085)
System Version: V3.146.0000000.3.R, Build Date: 2025-10-22
Web Version: V5.01.0.2338851
Algorithm Version: V5.10.20.1
Security Baseline Version: V2.4
H5Player Version: V3.01.1
Cloud Service Version: 2327855
Face Detection: R1482440.0_V3.005.0000000.0.R
People Counting: R1486745.0_V3.006.0000036.0.R
Video Metadata: R1489959.0_V2.010.0000000.7.R
Heat Map: R1486745.0_V3.006.0000036.0.R
IVS: R1515312.0_V2.010.0000000.0.R
AcuPick (Motor Vehicle): 1007001000004
AcuPick (Human Body): 1005001001004
1028 Firmware
System Version: V3.146.0000000.0.R, Build Date: 2025-10-28
Web Version: V5.01.0.2340775
