It looks like CP.AI is not working. Reboot your PC then run this test image to see if CP.AI worksAny idea why I need to use license-plate?
Here is one below going past my camera:![]()
Standard European style numberplates must start with the letter 'A' then a space which contains the ACT crest and bluebell logo, then a combination of 6 letters and numbers following the standard ACT 'Y' series format.
Yes and like you I tried to keep it under control using an automation, but I found a better way through BI. Under the AI settings in BI there is an option to restart CPAI every x number of minutes. I set mine to 720 (every 12 hours) and it works great.Anyone else experiencing memory leak with the ALPR module?
I ran your images through my setup with the same results. I think you've just got a bad angle on your plate captures.Do I need a better camera?
ALPR seems to be working, just not with my plate capture. Do I need a better camera? Although, it was working a few iterations ago.
View attachment 220633View attachment 220634
It's using your CPAI configuration.When I use CPAI Explorer, am I using ALPR analysis on my computer or is it using the cloud? In other words, if it works in COAI Explorer should it also work in BI?
How do I change the rotation degrees, or for that matter, height, width, etc?
Interesting troubleshooting:
