I would like to use CPAI. I suspect I am just not using the correct stuff or have it set up correctly. There is also a lot of older info out there so it becomes confusing given the cutting edge nature of this stuff. I appreciate any help you can provide. I have a NVIDIA card that can use CUDA so I would also like to be able to use CUDA for CPAI not just for license but also for AI of people and other stuff. I can see that I don't have cuDNN installed
Server version: 2.9.5
System: Windows
Operating System: Windows (Windows 11 24H2)
CPUs: Intel(R) Core(TM) i7-14700K (Intel)
1 CPU x 20 cores. 28 logical processors (x64)
GPU (Primary): NVIDIA GeForce RTX 4060 Ti (8 GiB) (NVIDIA)
Driver: 581.29, CUDA: 12.2.91 (up to: 13.0), Compute: 8.9, cuDNN:
System RAM: 128 GiB
Platform: Windows
BuildConfig: Release
Execution Env: Native
Runtime Env: Production
Runtimes installed:
.NET runtime: 9.0.9
.NET SDK: 9.0.305
Default Python: Not found
Go: Not found
NodeJS: Not found
Rust: Not found
Video adapter info:
Microsoft Remote Display Adapter:
Driver Version 10.0.26100.5074
Video Processor
NVIDIA GeForce RTX 4060 Ti:
Driver Version 32.0.15.8129
Video Processor NVIDIA GeForce RTX 4060 Ti
System GPU info:
GPU 3D Usage 0%
GPU RAM Usage 1.3 GiB
Global Environment variables:
CPAI_APPROOTPATH = <root>
CPAI_PORT = 32168
I was going to go to here
developer.nvidia.com
And get the latest. I am also not sure then if the custom model ipcam-combind is going to play well with things like Yolov8 which looks to be for modern GPU's (Which I think mine fits).
Again, thank you for any help
