I updated to .28. ALPR is working great. Here are my BI --> AI settings for reference:
Nothing happen when I have it unchecked. I need it checked for it to work apparently....but you have auto start enabled what shouldn't be needed any longer with .28.
I moved to .27 and enable the auto start. It works for me now.
I unchecked the box and restarted the BI service. It appears to be working.Would be nice if you could try unchecking and rebooting to see if it starts.
It’s not working on my end, but I might have a different issue. My BI machine uses a 10G SFP+ Ethernet interface, and the network initialization is slower than usual (taking 30–60 seconds after boot). This might be causing problems if the BI service starts before the network is ready.
If it works for you, I'll need to reach out to Ken to find a solution. If it doesn’t work for you either, then we’ll have to contact Ken anyway...
How many camera do you have if you need 10 Giga? I use maybe 50-60 mbps of my Gigabit link on the input...
Why would Ken need to weigh in on your SFP issue? Sounds like an IT issue.Ahh, it’s not about necessity—it’s because I can!
BI runs on a Windows 11 VM within an unRAID server, and I had an unused SFP+ port there what I could pass through to the VM. Plus, my core switch in the same rack cabinet had free SFP+ ports, so it was a no-brainer to connect them.
...but yeah, it seems like I have a problem now that I wouldn't have with normal 1G copper interface
...buy the way, sometimes I am thinking if it is actually worthwhile or not to run CPAI as a docker (again in my case in the same unRAID server), or it would be better to run it local in the same Windows VM together with BI.
Initially I thought it's more slick and efficient to run it separately in docker, but I am not that convinced anymore. Does anyone have an idea how to measure/ decide which approach is better?
What program is that iv never seen that ALPR feed before?I updated to .28. ALPR is working great. Here are my BI --> AI settings for reference:
It doesn't appear I need to check the "Use GPU" checked. Any info on that? I don't see anything in the help file.
Thank you for the reply!This program written by a member here. But make sure your BI is reliably reading plates before jumping to it. Too many people have jumped in that thread thinking it is magic.
You need to have this current thread working before jumping into the database program:
Hello everyone
I created this project as an alternative to the super expensive options from PlateMinder and Rekor. This still depends on your own CodeProject or DeepStack AI, but offers a nice all-in-one solution to actually use and make sense of the data, which is half the point of having the AI read the plates to begin with. It has been working great for me so far, really huge upgrade, so I wanted to share it.
I know there was a NodeRed app created a while ago that had some of this functionality. I took some inspiration from that and tried to bring it to the next level.
Would love to...
- algertc
- alerts alpr blue iris blue iris tools codeproject docker licence plate notifications
- Forum: Blue Iris Tools
It does work with Nvidia GPUs, what GPU do you have.does the ALPR module work with gpus or is it still only cpus? I for the life of me can't get it to work with my gpu. It will say its running but i never "reads" any plates.
3060ti in that machine. Gpu works fine for the yolo and the gpu alpr will start and says it’s running but it never even under testing will it find a resultIt does work with Nvidia GPUs, what GPU do you have.
It should work with your GPU, post a screenshot of your System Info like the below
