Hello!
I would really appreciate some advice on where to install cameras and which cameras would fit my needs. I've lurked for a while and tried to answer the basic questions below, I hope it isn't so much text that I get no replies
Purpose:
DORI goals: I'm aiming for between Observe and Recognize.
Current cameras: I have an Amcrest 2mp wifi flood light over the garage, and a mix of freestanding Foscam and Amcrest wifi cameras inside.
Plan:
Ask for Help:
I've attached a terrible MS paint of my property (it's a google map that I've doodled over so it's true to scale), and some rough measurements.
Thanks for the help!
Purpose:
- The primary objective is to have cameras pointing around the exterior of a 2 story house to be able to know where the kids are on my ~1/3 acre corner suburban lot.
- This is a less lofty goal than to visually identify an intruder, so at least at first I'm hoping to put up 5 or 6 cameras, just to obtain visibility of my yard and improving the system as needed next year.
- Obviously the system will double as security cameras in the event of intrusion, but that's not common around here.
- A stretch goal would be to have visibility of the park I'm adjacent to (400ft to the NW) so I can see if the kids have run over there.
Plan:
- Run ethernet to all the corners of the house and install cameras to be able to see every common play place at a glance.
- My first thought was turrets at each corner, the flood over the garage, and a doorbell cam, but I don't think that'll be enough coverage.
- I will also build a NAS/NVR (i5-12400, 32GB RAM, room for 8 HDD) and run BlueIris.
Ask for Help:
- I'm struggling with all the different cameras and models, even when only looking at EmpireTech. There seems to be no guide on which models are from which year, what the model numbers mean, etc. I was looking at the new IPC-T54PRO-ZE because it had the white light as well as IR and 2 way audio, and initial reports on here seemed to say it was a good camera.
- Where to place the cameras?
- the west side isn't used much so it can be a blind spot (for now)
- property lines are ~115ft long
- Driveway is 40ft long and slightly downhill.
- Garage is 25ft "tall" (driveway side), and 20ft deep (to the house).
- House is 35ft wide by 30ft tall
- NW corner of the house is almost at 3rd story height because of the walkout basement.
