How is it that your cpu use before and after direct to disk are the same.Screenshots are in this thread Need help tuning BI to stop Frozen frames, ghosting,
Windows 10 runs great..try it...refusing to try a solution simply hurts you, no one else.I don't know how it is the same. I was initially running 30fps but have it set to 15fps for now so maybe thats why. I do not have SD cards installed in any of my cameras. All cameras are basically all set to defaults other than disabling sub-stream and matching fps and iframe interval.
try using find inspect instead of dahua rtsp so it pulls the onvif profile. There are also several encode modes on the dahua camera try them all.I am running Win10x64 and bonsey is running Win7x64.
Did you test with h.264h?Ok...I have not tried that yet so I went ahead and made the changes and re-enabled direct-to-disk. Find/Inspect did find the onvif path. I checked my encode modes on the camera and all i have is h.264, h.264h, and mjpeg. As far as I know I dont want to use 264h or mjpeg so I dont think I have any other options there. Unfortunately still experiencing the problem.
Yes, generally you should not...Its called troubleshooting..I switched over to 264h and restarted everything and I still see the ghosting. I cant find the post right now but I believe I was told to make sure I was not running 264h. If I remember correctly I was running 264h so I switched over to h264 at that time.
disable RTSP Timecodes and Keepalive?
if you run netstat -s from cmd.exe do you have any interface errors or discarded packets?
a damaged/poor cable going to the BI Server or a cheap ass NIC could result in iframes being dropped and corrupting the video stream.
have you tried using one of the hikvision rtsp options instead of generic?I'll try the disabling the RTSP/Keepalives. A Netstat -S shows a pretty clean network. The entire house network is brand new run CAT6A that each link was tested to 10GB speeds. So I think a 8Mbit data stream over a 1GB connection shouldn't be pushing it too hard.
