Version 6
6.0.0.0 install went fine for me but last night I tried upping to 6.0.0.1 and it failed to install all files. Fortunately it did not mess up my system.
I'm not seeing this:
Do I need to be up to 5.9.9.9999999 before I can do a direct update to 6?
And we're up to 6.0.0.1 already! Is it soup yet? Or should I wait a few more bug fixes?
edit: updated screen capture to show active support contract.
I was under the impression someone above had done it from within BI. In that case, maybe that method isn't figured out yet or maybe it's just going to be impossible. I guess the options are wait and see or go the separate uninstall & install route.
I did three systems by just downloading the new installer from the BI website and running it, I had no issues! I did have to do the following after BI 6 was installed, add my service credentials and uninstall BI 5 after everything was up and running on V6. So far I have not seen any issues by using this method! My CPAI continued to work as before!
I'm thinking I may wait a while and see if they come up with an installer that put's it all on as before. Last thing I want to do is start trying to re-enter parameters because I look at the interface settings so infrequently, replicating them will be hard from memory.
It’s about a smooth as it’s ever going to get. Due to a change of the base BI folder the only real thing that needs to be done is select the option to run BI as a Service and enter the creds.
My experience, and from what I see, true for most others: run the installation of BI6 (preferably using the full package installer from the website, but it supposedly also works from the internal upgrade package as well now), BEFORE uninstalling BI5. This will transfer/ duplicate all of your previous settings from BI5. Simple and easy, don't over think this.
I absolutely would NOT suggest to uninstall BI5 first, then install BI6: how would you expect any program to know whether to retain all your previous settings in this situation? Keep the old BI5 in place, run the installer for BI6, then you have options: you can keep the old program and folders around for days or weeks if you want, then uninstall BI5 eventually at your convenience.
As others have mentioned, you will need to re-enter your user credentials in the BI6 settings for service startup. Also, as a side note: you might want to remove any desktop shortcuts to running BI5 so you don't accidentally click on those after switching over to fully running BI6 as a service: this will cause some errors/confusion both for you and in the program itself (don't ask, been there myself).
Is there going to be a way for people who stick with stable releases instead of latest updates to know when BI6 is officially a stable release?
V6 is already marked as stable. You will never be able to go from v5 to v6 without downloading the new installer.
