I had three systems running BI 5.x, One of them I did the upgrade to V6x via the full download from the BI site, the other two the upgrade to V6x was done by the normal update inside BI, both of these systems have the messed up version in the list of installed application, the full install is correct. On one of my systems with the messed up version numbers I did a registry backup of V6x and then uninstalled V5 and V6, then reinstalled V6 from the full download, upon reinstall everything was still there and did not require the import of the reg file and all the version numbers are now correct in the list of installed applications. My conclusion is that the versioning got mixed up do to doing the upgrade using the internal update procedure, anyone else who is contemplating doing an upgrade from V5x to V6x, should download the full install package. Now I just need to fix up my one remaining installation
