**UPDATED**SUCCESS**CRACKED*Swann PROPRIETARY camera-can't see it on the network-Swann SWNHD-865MSB
dave888
Joined
Mar 3, 2018
Messages
75
Reaction score
4
I get the error RTSP 400 Bad Request in BI when I try add camera.
dave888
Joined
Mar 3, 2018
Messages
75
Reaction score
4
deleted the cam and tried to re add it, correct password/username and get the error 80000007a
concord
Getting comfortable
Joined
Oct 24, 2017
Messages
671
Reaction score
757
I don't have any SWANN cams, but I noticed on your BL setup, you are using http:// and not rtsp:// in your Address. Also, you have the Video path: set to /ch(CAMN02)/0, but in your NVR setup, it states: /ch01/A with A:0 as the main stream..., so maybe /ch01/A:0 or /ch01/A0, etc...
Trying changing address to RTSP, like rtsp://user:p[email protected] or rtsp://user:p[email protected]:554, etc. If that doesn't work with the Video path you arleady have, try changing the Video path, as stated on your NVR.
(editor is changing the user: password to a laughing face, added space to show text...)
dave888
Joined
Mar 3, 2018
Messages
75
Reaction score
4
Concord, thanks for your reply, I tried the above what you advised but still no joy. Very frustrating. Just to confirm on the above, do you mean for example, rtsp://thepasswordforthecamera/192.168.1.60:554
concord
Getting comfortable
Joined
Oct 24, 2017
Messages
671
Reaction score
757
Yes, the username and password for the camera... RTSP port is 554, it may or may not be needed in the rtsp string...
Set Address to rtsp, then enter in:
TheUserNameFortheCamera:thePasswordFortheCamera@192.168.1.60
My bad, I was thinking that 192.168.1.60 was the cam, not the NVR. You maybe you can get the stream directly from the NVR, using the NVR username/password and /ch01/0 path
Check out other 8xx Swann cam RTSP suggestions:
Connect to Swann IP cameras
dave888
Joined
Mar 3, 2018
Messages
75
Reaction score
4
when you say the NVR do you mean the swann NVR? I do not own one, just using BI and these swann cams.
concord
Getting comfortable
Joined
Oct 24, 2017
Messages
671
Reaction score
757
Sorry, I thought your images in on post #41 was your NVR, not your camera. The cam states how to access via rtsp and the path (i.e. /ch01/0 for main stream), but it if entering in your username and password into BL, then trying: RTSP://192.168.1.60, or RTSP://192.168.1.60:554, or RTSP://username: [email protected] or RTSP://username: [email protected]:554 doesn't work, I'm not sure what else to try.
You could try accessing it with VLC to confirm that you can see video:
( VLC example:
and also you can use WireShark to discover rtsp strream too:
( WireShark example:
dave888
Joined
Mar 3, 2018
Messages
75
Reaction score
4
QUITE BIZARRE! - just thought id have a go on Wireshark, so hooked the cam up to my other pc, downloaded a trial of BI and selected the correct swann profile in BI, as I had done before and it's worked?! Il go try it on my BI pc now. Both are exactly the same spec win 10 machines. Strange.
dave888
Joined
Mar 3, 2018
Messages
75
Reaction score
4
It works fine, il try the other Swann cams i have tomorrow. How strange! Thanks for your help above.
dave888
Joined
Mar 3, 2018
Messages
75
Reaction score
4
For anyone reading this thread in the future make sure when you gain access to the Swann interface you tick Network:RTSP : Anonymous login is ticked.
Also some of my cams came out the box on a static 192 and other on a 172 address. Bit strange but hey ho.
Also on Network section tick UPNP and P2P Switch are both ticked to on
bc99
Joined
Feb 10, 2019
Messages
7
Reaction score
3
Location
USA
Just in case anyone is still trying to figure out the rtsp URL for the SWNHD-865msb so they can view it in VLC or Blue Iris, the URL is rtsp:/IP:554/ch01/0 - you can change the last 0 to 1 or 2 to lower the quality. This took me way too long to figure out. But I was able to view the stream over my network without ever connecting or owning a SWANN NVR or any other type of NVR. It's just connected to my POE switch which is connected to a router that has no internet connection. The streams feed into a machine with 2 ethernet ports so I can view the feeds from the non-internet connected network to my normal home network.
Neight
Joined
Jul 20, 2016
Messages
14
Reaction score
2
Hey guys. I am new to all of this and looking for some help. I purchased a swann NVR 8580 system with 4 of the 885 poe cameras. I was hoping to find a way stream the video do an Imperihome dashboard. I have tried to figure out a http stream for each individual camera with no luck. I then decided to try a tablet with tinycam running as a server to convert the rtsp streams to http. This works but after a few hours, the NVR stops all rtsp streams and the homesafe app fails to connect to the cameras as well. I then have to restart the NVR to get the rtsp streams back up. Do you guys have any ideas that I could try to get this working. I appreciate any help you could offer.
Neight
Joined
Jul 20, 2016
Messages
14
Reaction score
2
I don't have a swann system, but just googled and it seems that ImperiHome is still working on RTSP and recommends MJPEG instead ( How to configure my IP Camera ? ).
Unfortunately, direct stream from rtsp does not work in Imperihome from this system. It seems like Imperihome does not support H265. H264 streams from other sources work fine.
TechGecko
Joined
May 4, 2019
Messages
1
Reaction score
Location
Aus
Hello,
All Swann cameras mentioned in this thread are wired and with PoE, I have a Swann
SWNVK-490KH2 wireless w/ NVR model hoping for a similar outcome getting ONVIF or RTSP to work if anyone is familiar with the newer .
Cheers
user8963
Joined
Nov 26, 2018
Messages
1,465
Reaction score
2,315
Location
Christmas Island
Hello guys,
i hooked a 865MSB to a TTL interface..
maybe someone can help to find the original camera ? I can not believe that swann produce their own cameras...
here is the output:
Code:
IPL g125032b
D-06
WDT Reset
128MB
BIST0_0001-OK
[SDMMC] NO SD!
[NOR]
size:8190 chks:760d659f ok
IPL_CUST g125032b
MXP found at 0x00003000
[SDMMC] NO SD!
  decomp_size=0x0003f198
U-Boot 2015.01 (Jun 15 2017 - 09:54:33)
Version: I3g#######
I2C:   ready
DRAM:  64 MiB
WARNING: Caches not enabled
MMC:   MStar SD/MMC: 0
nor_flash_mxp allocated success!!
MXIC REMS: 0xC2,0x16
Flash is detected (0x050A, 0xC2, 0x20, 0x17)
SF: Detected nor0 with total size 8 MiB
MXP found at mxp_offset[0]=0x00003000, size=0x1000
env_offset=0x3F000 env_size=0x1000
In:    serial
Out:   serial
Err:   serial
gpio[16] is 0
Net:   MAC Address xx:xx:xx:xx:xx:xx
Auto-Negotiation...
AN failLink Status Speed:10 Full-duplex:0
Status Error!
mstar_emac
[NetUpgrade] ts_1st=0x1002
MDrv_EMAC_start
RBQP_BASE=0x23fac000
[NetUpgrade] Get Device MacAddr(xx:xx:xx:xx:xx:xx)
NetUpgrade Timeout
[NetUpgrade] ts_1st=0x1002, ts_2nd=0x13f2, delt_ts=0x3f0
SF: 1703936 bytes @ 0x40000 Read: OK
## Booting kernel from Legacy Image at 21000000 ...
   Image Name:   MVX2##I3ge3ce58aKL_LX318####[BR:
   Image Type:   ARM Linux Multi-File Image (lzma compressed)
   Data Size:    1648920 Bytes = 1.6 MiB
   Load Address: 20008000
   Entry Point:  20008000
   Contents:
      Image 0: 1573896 Bytes = 1.5 MiB
      Image 1: 75012 Bytes = 73.3 KiB
   Verifying Checksum ... OK
## Loading init Ramdisk from multi component Legacy Image at 21000000 ...
   Uncompressing Multi-File Image ...
[XZ] !!!reserved 0x21000000 length=0x 1000000 for xz!!
   XZ: uncompressed size=0x421ac0, ret=7
OK
initrd load to 0x20FE0000.[0x21180454, 0x00012504]
atags:0x20000000
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 3.18.30 (tuzuguo@dev) (gcc version 4.8.3 20140401 (prerelease) (crosstool-NG linaro-1.13.1-4.8-2014.04 - Linaro GCC 4.8-2014.04) ) #10 PREEMPT Tue Nov 7 16:06:58 CST 2017
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
early_atags_to_fdt() success
Machine model: INFINITY3 MSC000A-S04A
Reserved memory: created CMA memory pool at 0x23000000, size 80 MiB
Reserved memory: initialized node cma0, compatible id shared-dma-pool
Memory policy: Data cache writeback
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32510
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 mtdparts=NOR_FLASH:256K(boot),1664K(kernel),2560K(rootfs),3456K(app),64K(www),64K(para),64K(p2p),64K(log)
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 43196K/131064K available (2898K kernel code, 238K rwdata, 976K rodata, 116K init, 148K bss, 87868K reserved)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xffe00000   (2048 kB)
    vmalloc : 0xc8800000 - 0xff000000   ( 872 MB)
    lowmem  : 0xc0000000 - 0xc8000000   ( 128 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc03d0de8   (3876 kB)
      .init : 0xc03d1000 - 0xc03ee000   ( 116 kB)
      .data : 0xc03ee000 - 0xc0429ac0   ( 239 kB)
       .bss : 0xc0429ac0 - 0xc044ed08   ( 149 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
        Dump stacks of tasks blocking RCU-preempt GP.
NR_IRQS:16 nr_irqs:16 16
Find CLK_cpupll_clk, hook ms_cpuclk_ops
[ms_cpuclk_init] get dvfs gpio  vid_1
Architected cp15 timer(s) running at 6.00MHz (virt).
sched_clock: 56 bits at 6MHz, resolution 166ns, wraps every 2863311527936ns
Switching to timer-based delay loop, resolution 166ns
console [ttyS0] enabled
Calibrating delay loop (skipped), value calculated using timer frequency.. 12.00 BogoMIPS (lpj=60000)
pid_max: default: 4096 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0x202bf3a0 - 0x202bf3f8
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
Version : MVX2##I3ge3ce58aKL_LX318####[BR:gI3/master]#XVM
GPIO: probe end
MSYS:  INIT DONE. TICK=0x04C4CB61
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource arch_sys_counter
NET: Registered protocol family 2
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 2, 20480 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP: reno registered
UDP hash table entries: 128 (order: 0, 6144 bytes)
UDP-Lite hash table entries: 128 (order: 0, 6144 bytes)
Unpacking initramfs...
Freeing initrd memory: 76K (c0fe0000 - c0ff3000)
futex hash table entries: 16 (order: -4, 448 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
jffs2: version 2.2. © 2001-2006 Red Hat, Inc.
msgmni has been set to 244
io scheduler noop registered
io scheduler deadline registered (default)
i2c /dev entries driver
logger: created 256K log 'log_main'
[ms_uart_probe] uart port 0 use MUX_PM_UART
1f221000.uart0: ttyS0 at MMIO 0x0 (irq = 98, base_baud = 10750000) is a unknown
[ms_uart_probe] uart port 1 use MUX_UART1
1f221200.uart1: ttyS1 at MMIO 0x0 (irq = 99, base_baud = 10750000) is a unknown
URDMA rx_buf=0xC3042000(phy:0x23042000) tx_buf=0xC3043000(phy:0x23043000) size=0x1000
[ms_uart_probe] uart port 2 use MUX_UART0
1f220400.uart2: ttyS2 at MMIO 0x0 (irq = 112, base_baud = 10750000) is a unknown
infinity-audio soc:sound: ASoC: CODEC DAI infinity-codec-dai-main not registered
platform soc:sound: Driver infinity-audio requests probe deferral
infinity-audio infinity-codec: ASoC: CODEC DAI infinity-codec-dai-main not registered
platform infinity-codec: Driver infinity-audio requests probe deferral
netif_napi_add() called with weight 128 on device eth%d
[EMAC]Init EMAC success! (add delay in reset)
[SCL] SCL init success
mload_size = 35040
mload_virt_addr = c3090000
mload_dma_addr = 0x23090000
AE Base: virt=0xC30A0000
AWB Base: virt=0xC30AB400
AF Base: virt=0xC30B3B00
MOT Base: virt=0xC30B3EE0
HISTO Base: virt=0xC30B3BF0
RGBIR Base: virt=0xC30BAD20
[ISP] register driver success
[CSI] register driver successms_rtc 1f002400.rtc: rtc core: registered 1f002400.rtc as rtc0
[ms_rtc_probe]: rtc setup, frequency=12000000
[SAR] infinity_sar_probe
[Ser flash] phys=0x23046000, virt=0xc3046000, bus=0x03046000
[FSP] MXIC REMS: 0xC2,0x16
[FSP] Flash is detected (0x050A, 0xC2, 0x20, 0x17) ver1.1
[FSP] 1-1-2 DUAL_FAST_READ MODE
mtd .name = NOR_FLASH, .size = 0x00800000 (8MiB)
 .erasesize = 0x00010000 .numeraseregions = 0
MXP_PARTS!!
8 cmdlinepart partitions found on MTD device NOR_FLASH
Creating 8 MTD partitions on "NOR_FLASH":
0x000000000000-0x000000040000 : "boot"
0x000000040000-0x0000001e0000 : "kernel"
0x0000001e0000-0x000000460000 : "rootfs"
0x000000460000-0x0000007c0000 : "app"
0x0000007c0000-0x0000007d0000 : "www"
0x0000007d0000-0x0000007e0000 : "para"
0x0000007e0000-0x0000007f0000 : "p2p"
0x0000007f0000-0x000000800000 : "log"
[ms_cpufreq_init] cpu current clk=796917760
TCP: cubic registered
NET: Registered protocol family 17
[mstar_pm_init] resume_pbase=0x203F94F4, suspend_imi_vbase=0xC90AE000
ThumbEE CPU extension supported.
infinity-audio soc:sound: infinity-codec-dai-main <-> infinity-cpu-dai mapping ok
ms_rtc 1f002400.rtc: setting system clock to 1970-01-01 00:02:29 UTC (149)
ALSA device list:
  #0: infinity_snd_machine
Freeing unused kernel memory: 116K (c03d1000 - c03ee000)
init: SERVICE: ueventd
init: Unable to open persistent property directory /data/property errno: 2
init: SERVICE: log
init: SERVICE: rcs
: not found/init.d/log: line 3:
mount: mounting /dev/block/mtdblock4 on /plugs failed: Invalid argument
(none) login: mount: mounting tmpfs on /etc/ppp failed: No such file or directory
cp: can't stat '/ppp/*': No such file or directory
open the /dev/block/mtdblock6 sucessed
  producttype : RS-CH256MCC-36PW-M-PIR-SW
  SenSorType: SC5035_5M
  BoardType: RS-CM-211B
  ChipType:
=============24
cp /mnt/srcsensorlib/libsns_sc5035.so /mnt/sensorlib/libsensor.so
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
mstar notify driver install successfully
insmod: can't read '/lib/modules/usb-common.ko': No such file or directory
insmod: can't read '/lib/modules/usbcore.ko': No such file or directory
insmod: can't read '/lib/modules/ehci-hcd.ko': No such file or directory
insmod: can't read '/lib/modules/cfg80211.ko': No such file or directory
insmod: can't read '/lib/modules/mtprealloc.ko': No such file or directory
insmod: can't read '/lib/modules/mt7601Usta.ko': No such file or directory
rtc_ds1339 driver init successful(software:0)!
* rsSystemServer version:V1.1 *
listening ...
BANK:0xE 16bit-offset 0x09
0x0000
killall: boa: no process killed
here2,FuncCodeUsedFlag=USEDFC,pFuncCodeMagic=USEDFC
pFunctionCode =@
fun: LoadConfig, line: 241, 356MKB not ok
fun: LoadConfig, line: 252, 485 not ok
fun: LoadConfig, line: 269, mac in ok
here15,CustomTypeUsedFlag=,pCustomMagic=CUMTYP
AppVersion=V2.1.3.4_171220
AppVersion=.1.3.4_171220
[PARAM] <LoadConfigFile>(2030)  Debug Info: DebugMode         = 0
[PARAM] <LoadConfigFile>(2031)  Debug Info: LanguageMaskExtend = 0x0
[PARAM] <LoadConfigFile>(2032)  Debug Info: LanguageMask      = 0x10
[PARAM] <LoadConfigFile>(2033)  Debug Info: CurLanguage       = 4
[PARAM] <LoadConfigFile>(2034)  Debug Info: IECustomer        = 23
[PARAM] <LoadConfigFile>(2035)  Debug Info: AppVersion        = V6.1.3.4_171220
[PARAM] <LoadConfigFile>(2036)  Debug Info: IEVersion         = v1.0.2.62_170713
[PARAM] <LoadConfigFile>(2037)  Debug Info: RecToFileEnable   = 0
[PARAM] <LoadConfigFile>(2038)  Debug Info: IntelligentEnable = 1
[PARAM] <LoadConfigFile>(2039)  Debug Info: ReFactoryEnable   = 0
[PARAM] <LoadConfigFile>(2040)  Debug Info: WifiEnable        = 0
[PARAM] <LoadConfigFile>(2041)  Debug Info: FtpEnable         = 1
[PARAM] <LoadConfigFile>(2042)  Debug Info: RtspEnable        = 1
[PARAM] <LoadConfigFile>(2043)  Debug Info: OnvifEnable       = 1
[PARAM] <LoadConfigFile>(2044)  Debug Info: EmailEnable       = 1
[PARAM] <LoadConfigFile>(2045)  Debug Info: DdnsEnable        = 1
[PARAM] <LoadConfigFile>(2046)  Debug Info: UpnpEnable        = 1
[PARAM] <LoadConfigFile>(2047)  Debug Info: PlatformEnable    = 1
[PARAM] <LoadConfigFile>(2048)  Debug Info: DstEnable         = 1
[PARAM] <LoadConfigFile>(2049)  Debug Info: NtpEnable         = 1
[PARAM] <LoadConfigFile>(2050)  Debug Info: DualTalkEnable    = 0
[PARAM] <LoadConfigFile>(2051)  Debug Info: IRCutEnable       = 1
[PARAM] <LoadConfigFile>(2052)  Debug Info: NetAdjustEnable   = 0
[PARAM] <LoadConfigFile>(2053)  Debug Info: FtpUpgradeEnable  = 0
[PARAM] <LoadConfigFile>(2054)  Debug Info: LogEnable         = 1
[PARAM] <LoadConfigFile>(2055)  Debug Info: AutoFocusEnable   = 0
[PARAM] <LoadConfigFile>(2056)  Debug Info: IPV6Enable                  = 0
[PARAM] <LoadConfigFile>(2057)  Debug Info: NTSCFormat                  = 0
[PARAM] <LoadConfigFile>(2058)  Debug Info: P2pType           = 7
[PARAM] <LoadConfigFile>(2059)  Debug Info: PushType          = 1
[PARAM] <LoadConfigFile>(2060)  Debug Info: WorkModeEnalbe    = 1
[PARAM] <LoadConfigFile>(2061)  Debug Info: IRISEnable          = 0
[PARAM] <LoadConfigFile>(2062)  Debug Info: KeyBoardEnable    = 0
[PARAM] <LoadConfigFile>(2063)  Debug Info: JPEGEnable          = 0
[PARAM] <LoadConfigFile>(2064)  Debug Info: AreaEncodeEnable  = 0
[PARAM] <LoadConfigFile>(2065)  Debug Info: UseRes2M                = 0
[PARAM] <LoadConfigFile>(2066)  Debug Info: UseParamControl     = 0
[PARAM] <LoadConfigFile>(2067)  Debug Info: UseElectricity      = 0
<LoadConfig> (354) _IE_CUSTOMER_ = 7
[PARAM]  Debug Info: FileName:./custom/SWANN_config!
[COMMON]  Debug Info: find failed
Custom=0007,CurLang=0004,Language=00000010,LanguageExtend=
[MAINTHREAD] <LoadConfig>(382)  Debug Info: IECustomer:7,CurLanguage:4,LanguageMask:10,LanguageMaskExtend:0
[PRODUCTTYPE] <ParseProductType>(48)  Debug Info: ParseProductType OK
[PRODUCTTYPE] <ParseCameraType>(126)  Debug Info: ParseCameraType OK
[PRODUCTTYPE] <ParseCameraApearance>(161)  Debug Info: ParseCameraApearance OK
[PRODUCTTYPE] <ParseSensorResolution>(203)  Debug Info: ParseSensorResolution OK
[PRODUCTTYPE] <ParseChipBrand>(244)  Debug Info: ParseChipBrand OK
[PRODUCTTYPE] <ParseSensorScheme>(279)  Debug Info: ParseSensorScheme OK
[PRODUCTTYPE] <ParseAudioFlag>(340)  Debug Info: ParseAudioFlag OK
[PRODUCTTYPE] <ParseGlobalFunction>(361)  Debug Info: ParseGlobalFunction OK
[PRODUCTTYPE] <ParseAutoFocusFlag>(384)  Debug Info: ParseAutoFocusFlag OK
[PRODUCTTYPE] <ParseWDRFlag>(408)  Debug Info: ParseWDRFlag OK
[PRODUCTTYPE] <ParseAFLensType>(424)  Debug Info: ParseAFLensType OK
[PRODUCTTYPE] <ParsePOEFlag>(470)  Debug Info: ParsePOEFlag OK
[PRODUCTTYPE] <ParseBOX485Flag>(487)  Debug Info: ParseBOX485Flag OK
[PRODUCTTYPE] <ParseSensorAndChip>(505)  Debug Info: ParseSensorAndChip OK
coming the initGPIO
[MAINTHREAD]  Debug Info: InitGPIO success!
[WATCHDOG]  Debug Info: hi_api_wdt_settimeout(60000ms)
[MAINTHREAD]  Debug Info: InitWatchDog success!
InitSensorCfg sensorType=24, chipType=0
[PARAM] <InitSysParam>(34)  Debug Info: m_pRsIpcParam.size = 53,RsIpcParam_t Size = 25792
FLASH 25792, UserName (admin).97.100.109.105.110.0).(123456).49.50.51.52.53.54)
[PARAM] <CheckSchedulePara>(3304)  Debug Info: There is no need to check schedule para!
[PARAM]  Debug Info: <ModifyCheckParameter> param type error,type:49
[PARAM]  Debug Info: param type: 49 error!!
[PARAM]  Debug Info: param type: 50 error!!
[PARAM]  Debug Info: Save param to flash OK!
[MAINTHREAD]  Debug Info: KEY:bootVersion=V140101 kernelVersion=V140101 rootfsVersion=V170829
g_S32UbootFd open failed(/dev/mtdblock0)
g_S32KernelFd open failed(/dev/mtdblock1)
g_S32RootfsFd open success rootfsversion.conf
[MAINTHREAD]  Debug Info: READ:bootVersion=V140101 kernelVersion=V140101 rootfsVersion=V170829
[MAINTHREAD]  Debug Info: keyParam.DeviceName=NHD-865, DeviceType=NHD-865
[MAINTHREAD]  Debug Info: keyParam.ClientPort=9988, WebPort=80
[MAINTHREAD]  Debug Info: InitSysParam success!
<HttpFunctionSwitch>:(12),
[MAINTHREAD]  Debug Info: datetime:2015, 1, 1, 9, 45, 21
=============timezone = 13
[COMMON]  Debug Info: timezone env:GMT-8
[MAINTHREAD]  Debug Info: InitRtc success!
[MAINTHREAD]  Debug Info: InitLog success!
[MEDIA] <ViDevAttrCfg>(96)  Debug Info: !!!!!*****************************ViDevAttrCfg
[MEDIA] <GetViVpssWorkMode>(1463)  Debug Info: Msc Platform Do not Support Get Vi Vpss Work Mode
[RSOsd]: open font(/mnt/font/yahei_arial_gothic_unicode_19_50.qpf2) success !
[MI_SYS_Init]MI version:MVX2####g9ddb145MI##########[BR:I3/sz0608]#XVM
[MI_SYS_Init]MI log level:2
[MI_SYS_Init]MI log module:0xffffffff
init: save mstar property to /data/mstar.prop
random: init urandom read with 10 bits of entropy available
<6275 ms>       OMX[100]        OMX log level:1
<6275 ms>       OMX[100]        OMX log modularfilter :0
<6275 ms>       OMX[100]        enable memory leak check!
mi-info:        ISP_Wraper_init
mi-info:        bShrinkMem:1
mi-info:        _MI_OSD_Init_Prop gop_use:0
mi-info:        OmxComponentCreate: name = OMX.mstar.video_src.camera.vjpg
0x1,0x1
[ISP]MaxWidth=4096
mclk ISP_27M
[DMA]: Transfer NOT Completely!
ERROR: Bus[1] in ms_i2c_xfer_write: Slave dev NAK, Addr: 0x60, Data: 0x31 0x7
Read RegisterPair set register: Connection timed out
mclk ISP_27M
dlopen failed, libdrv_ms_cus_ov4689_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ov4689_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_imx123_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_imx123_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_ar0237.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ar0237.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_sc2135.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_sc2135.so
mclk ISP_36M
dlopen failed, libdrv_ms_cus_imx291_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_imx291_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_ov2718_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ov2718_MIPI.so
mclk ISP_21P6M
dlopen failed, libdrv_ms_cus_ov2735_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ov2735_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_ar0330_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ar0330_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_ov4686_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ov4686_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_BRV0500_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_BRV0500_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_ar0237_RGBIR.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ar0237_RGBIR.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_ov2775_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ov2775_MIPI.so
mclk ISP_12M
dlopen failed, libdrv_ms_cus_POA030.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_POA030.so
mclk ISP_12M
dlopen failed, libdrv_ms_cus_imx326_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_imx326_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_ar0521_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ar0521_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_OS05A10_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_OS05A10_MIPI.so
mclk ISP_12M
dlopen failed, libdrv_ms_cus_ov2710_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ov2710_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_ps5510_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ps5510_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_ov9756_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_ov9756_MIPI.so
mclk ISP_12M
dlopen failed, libdrv_ms_cus_BRV0200_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_BRV0200_MIPI.so
mclk ISP_27M
dlopen failed, libdrv_ms_cus_OS08A10_MIPI.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_OS08A10_MIPI.so
mclk ISP_12M
dlopen failed, libdrv_ms_cus_pattern.so: cannot open shared object file: No such file or directory
Failed to load libdrv_ms_cus_pattern.so
[src/drv_ms_isp_hal.c/CleanupHandler] Thread cleanup handler
ms_proc_munmap_device: handle argument is not a device
malloc count = 0
fopen count = 0
open count = 1
dlopen count = 0
<7265 ms>       OMX[100]        omx_videosrc_component_Constructor (line 1435) open camera failed <0x80001009>
<7265 ms>       OMX[100]        Error during component construction <80001009> for comp name <OMX.mstwatchdog watchdog0: watchdog did not stop!
ar.video_src.camera.vjpg>
<7594 ms>       OMX[100]        VSRC Port<0> Buffer Count: <2>
<7594 ms>       OMX[100]        MAX: <0> MIN: <0> AVG <nan> Qtimes <0>
<7595 ms>       OMX[100]        VSRC Port<1> Buffer Count: <2>
<7595 ms>       OMX[100]        MAX: <0> MIN: <0> AVG <nan> Qtimes <0>
mi-error:        OmxComponentCreate:574 OMX_Wraper_GetHandle error:ErrorHardware
mi-error:       [_MI_VI_Init:971] OmxComponentCreate err=ErrorHardware
mi-info:        _MI_VI_Deinit Exit
mi-error:        _MI_VI_Init: init failed
[MEDIA] <SysInit>(32)  Debug Info: Mi sys init failed  = -1
MEDIA VERSION: 2017-10-12 14:00:25 V01.00.03 MSC318 IPC_app_ch256_swann_170915
[MEDIA]  Debug Info: printf Mi version is MS_API[MI_1.0.0]
[MEDIA]  Debug Info: media initial sys success!
mi-error:       MI_ISP_Init Cannot get hISPHandle.
[ISP] <Init>(601)  Debug Info: MI_ISP_Init failed! ret=6
 !!!!****** isp_type_Consumer_control=RS-CH256MCC-36PW-M-PIR-SW, Consumer=7
 isp_type_Consumer_control CAMERA_type=0,CAMERA_Consumer=7
 THE sensor lib  version  is box CH256 v1.4.2 20170802 11:57
[MI_VI_SetDevAttr 1659] err Invalid handle!
[MEDIA] <ViSetDevAttr>(55)  Debug Info: set vi dev attr err
mi-info:        MI_VI_SetChnAttr chn:0 width = 2592 ,height = 1944 , format = 5, mode = 0
[MI_VI_SetChnAttr 1732] err Invalid handle!
[MEDIA] <ViSetChnAttr>(88)  Debug Info: set vi chn(0) attr err
[MI_VI_EnableChn 1793] err Invalid handle!
[MEDIA] <ViEnableChn>(124)  Debug Info: enable vi chn(0) err
[MEDIA] <Convert2MiPixelFormat>(255)  Debug Info: Not Support enRsPixelFormat=0
mi-info:        MI_VI_SetChnAttr chn:3 width = 640 ,height = 480 , format = 5, mode = 0
[MEDIA] <ViSetChnAttr>(88)  Debug Info: set vi chn(3) attr err
[MEDIA] <ViEnableChn>(124)  Debug Info: enable vi chn(3) err
mi-info:        MI_VI_SetChnAttr chn:4 width = 640 ,height = 480 , format = 5, mode = 0
[MEDIA] <ViSetChnAttr>(88)  Debug Info: set vi chn(4) attr err
[MEDIA] <ViEnableChn>(124)  Debug Info: enable vi chn(4) err
mi-info:        MI_VI_SetChnAttr chn:5 width = 320 ,height = 180 , format = 5, mode = 1
[MEDIA] <ViSetChnAttr>(88)  Debug Info: set vi chn(5) attr err
[MEDIA] <ViEnableChn>(124)  Debug Info: enable vi chn(5) err
mi-error:       _MI_ISP_StatusCheck hISPHandle invalid.
[MEDIA] <ViSetIspInputCrop>(222)  Debug Info: vi set SetInputCrop err
[ALGO_MSG_ERR] [IaaAec_GetBufferSize] Working buffer size = 357196 bytes
[IaaApc_GetBufferSize] Working buffer size = 65620
Checking IC....
[APC] APC IC check pass. ver.2017.0718.0000
[APC] Point Number: 256
This platform has Neon.
FFT is floating point mode
¶z--------------------------------------------------------------------------------¶{
¶x        ¶x
¶x                                   NEON ENABLE                                  ¶x
¶x        ¶x
[AGC] AGC IC check pass. ver.2017.0718.0000
[WNR] Working buffer size: 4140 bytes
sndchn = 0
[ALGO_MSG_MSG] [WNR] IC check pass. ver.2016.621.0
mi-info:        PORT[1] on/off[0],line:4161.
mi-info:        PORT[2] on/off[0],line:4161.
mi-info:        PORT[3] on/off[0],line:4161.
mi-info:        PORT[4] on/off[0],line:4161.
----<Init>[38]m_u32FontMaxHeight = 28 m_u32FontMaxWidth = 28 ------
Creat queue id:0
queue id:0
onvif g_semId = 0, g_msgId = 0
------------> allready open max_fd 1024
========= discovserver.c  line 1068  Enter onvif_scan
queue id:0
Version: I3g#######
I2C:   ready
DRAM:  64 MiB
In:    serial
Out:   serial
Err:   serial
gpio[16] is 0
Auto-Negotiation...
Status Error!
mstar_emac
MStar # <INTERRUPT>
MStar # <INTERRUPT>
MStar p
Unknown command 'hel' - try 'help'
MStar # help
?       - alias for 'help'
base    - print or set address offset
bootm   - boot application image from memory
bootp   - boot image via network using BOOTP/TFTP protocol
cmp     - memory compare
cp      - memory copy
crc32   - checksum calculation
dbg     - set debug message level. Default level is INFO
dcache  - enable or disable data cache
debug   - Disable uart rx via PAD_DDCA to use debug tool
dhcp    - boot image via network using DHCP/TFTP protocol
dstar   - script via SD/MMC
eeprom  - EEPROM sub-system
env     - environment handling commands
estar   - script via network
estart  - EMAC start
fatinfo - print information about filesystem
fatload - load binary file from a dos filesystem
fatls   - list files in a directory (default /)
fatread - FAT fatread with FSTART
fatsize - determine a file's size
go      - start application at address 'addr'
gpio    - Config gpio port
help    - print command description/usage
i2c     - I2C sub-system
icache  - enable or disable instruction cache
initDbgLevel- Initial varaible 'dbgLevel'
loop    - infinite loop on address range
macaddr - setup EMAC MAC addr
md      - memory display
mm      - memory modify (auto-incrementing address)
mmc     - MMC sub system
mmcinfo - display MMC info
mssdmmc - Mstar SD/MMC IP Verification System
mstar   - script via TFTP
mw      - memory write (fill)
mxp     - MXP function for Mstar MXP partition
net_upgrade- do net update from the specified file that is in tftpserver
nm      - memory modify (constant address)
ping    - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
reset   - Perform RESET of the CPU
riu     - riu  - riu command
run     - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv  - set environment variables
sf      - SPI flash sub-system
sfbin   - for uploading sf image to a server(via network using TFTP protocol)
srcfg   - sensor pin and mclk configuration.
tftpboot- boot image via network using TFTP protocol
version - print monitor, compiler and linker version
MStar #
MStar # version
arm-linux-gnueabihf-gcc (crosstool-NG linaro-1.13.1-4.8-2014.04 - Linaro GCC 4.8-2014.04) 4.8.3 20140401 (prerelease)
GNU ld (crosstool-NG linaro-1.13.1-4.8-2014.04 - Linaro GCC 4.8-2014.04) 2.24.0.20140311 Linaro 2014.03
alastairstevenson
Staff member
Joined
Oct 28, 2014
Messages
15,980
Reaction score
6,802
Location
Scotland
I don't see @alastairstevenson here lately.
Lol! I wish ...
I can't say I've seen another brand of 5MP bullet with a built-in PIR. But then it's not something I've looked for.
Google doesn't come up with much - closest was this : 5MP PIR Bullet IP Camera | Concord
But no firmware download links.
The next step would be to google some of the machine or model specific strings from the bootlog.
This yields a bootlog from probably another (unknown) camera : andy2301/test1
The bootlog suggests it's from the same family of firmware.
But these don't look like a match - despite the bootlog title : Yi Technology
This didn't yield anything useful :
But this might be worth searching for :
producttype : RS-CH256MCC-36PW-M-PIR-SW SenSorType: SC5035_5M BoardType: RS-CM-211B
Sometimes a bootloader environment variable holds an original model number, so it may be worth using
printenv
at the bootloader prompt.
Top
