Update on the camera (SWNHD-886MSD) capabilities:
PIR and Motion detection seem to work as a motion Onvif event that BI can see. But there is no PIR only option in the interface. There is Motion or (PIR+ Motion), I can only assume that PIR+ Motion is less sensitive to leaf motion and more sensitive to heat signatures.
The camera has some intelligent alarms like person detection, face, object, intrusion, but they do not seem to fire any Onvif events. This is annoying because it means the server CPU would have to be used for these, but from what I read this seems the case for most cameras so not a huge deal, but it is a disadvantage over the NVR that can see these.
The intelligent events do have an option to send an email so there might be a workaround.
I will try to write an SMTP demon that grabs the email and sends an http command to the synology station, I think a similar solution can be made to work for BI as well, prolly simpler to do on a pc.
