Just got one of these for testing. 5 minutes into testing the IVR indoors, the camera went into continuous spinning? I had to log back into the web interface and reset the PTZ to get it working again (or a power cycle would have done the same).
I haven't found anything about the cause of this? I have it being fed power from a poe+ switch, dedicated IP. The camera itself never lost power or the video signal. Just the stock cam purchase from Amazon, which says I'm on "the latest firmware" according to the built-in webserver - I imagine many have received the camera in the same state.
System Version2.800.1341000.0.R, Build Date: 2020-03-12
PTZ Version2.401.0000000.64.RHNZ_200219_34642
It is the latest version
Worried of it happening again after installation outside. Any known fix for this behavior that I'm not seeing in searching this thread and theipcamtalk forum?
Are you controlling it through Blue Iris? I’ve had it occasionally with mine where it’s like it gets stuck on the pan command and will do a few 360s. I either have to hit stop or another direction to get it to clear.. and sometimes a few attempts. Almost like Blue Iris tells it to pan right, then there is a communication glitch and it doesn’t get the command to stop panning.
