FlipNJ
Pulling my weight
- May 3, 2016
- 372
- 137
Takes soooo much time to find the sweet spot. You will find that there will be so many little things you want to control but can't. I also experience the loss of track when a target stops however I find it is a double edged sword. There may be times when another target is at the home position and if the cam was lollygagging in a different position, you will miss it. For me, spotter setup is also very time consuming and little things cause issues. Things like when it is dark out, a car's headlights will cast a beam in an area where a spotter triggers the ptz but it is only the beam of light there so now, the ptz is looking at nothing interesting. Still fun to mess with different things.Thanks all...I'll keep playing with it. I am currently using 3 spotter cams which seem to work great. Now i'll start messing with tracking size at each preset.
