Cameraguy
- Feb 15, 2017
- 1,507
- 1,162
What is curl?Then maybe their cloud service is down?
I tried to find an API for the DB11 but no luck otherwise you could use curl and send key/value for the chime settings.
Ok.. if anyone figures it out let me knowIt’s a command sent with a url.
It's still an aggravating product in the end.
Works perfect using bi.. only thing I'm missing is the chime setting in the imou app.. once I get that turned on it will be perfectYes! I've unplugged mine. Too many problems and still unreliable.
But, isn’t that the whole point?Works perfect using bi.. only thing I'm missing is the chime setting in the imou app.. once I get that turned on it will be perfect
Got db add to imou app.. went on PC and added thru lechange website. but see nothing about chime.. here is a pic of my add screenThen maybe their cloud service is down?
What problems you experienced? I mean beside the crappy app, which I don’t really use. With BI all is good. I just wish we can figure out the 2 way audio via BI then I’m going to retired the stupid app.
Outside of the app dropping the connection sporadically and the bell ringing nonstop after someone presses it once, it was more problems than its worth at the moment for me. I never attempted to add it BI because of the problems I mentioned earlier. Maybe I'll revisit it again after the holidays......
So after trying 5 different devices with no luck.. I broke out my old Samsung s7.. I'll be damned, it connected db to imou app.. I'm in boys.. now need to figure out the chime kit setupLooks completely different to the iOS app. Do they have screenshots in the manual for android? And did you check on their website it you can do changes to the camera settings?
Well the shit show is over. It's all hooked up.. inside chime works with kit.. working with bi.. now get 2 way talk working and all good.. thanks guys. And thanks to @EMPIRETECANDY what a great salesman we have hereSo after trying 5 different devices with no luck.. I broke out my old Samsung s7.. I'll be damned, it connected db to imou app.. I'm in boys.. now need to figure out the chime kit setup
the dahua api is all over this forum and the internet. It wont help you as you wont be able to implement any changes in BI. For most dahua cameras the talk function works if you select the second dahua option from the dropdown in BI. 2320.It would be awesome if the great salesman can get his hands on the API document.
There is no BI "team". its one guy. He will have no use for the api or anything else as its clear that no one including you had messaged him to indicate you are having an issue. As stated, the dahua api is all over this forum and is widely available. Google. You will not be able to change the chime repetition with the api.It will help me to eventually change the annoying 10 times chime (if that’s not hard coded in the FW) and it eventually will be useful for the BI team.
