FYI: That info was in the instruction pamphlet, that came with my review unit cam.
The documents that ship with the camera now does not contain this hard reset info.
Connect to the db11 with the tool IP config and see if that gives you the option to adjust the speaker.Got the DB11 installed. Works fine. Just have a small issue: the loudspeaker at the doorbell itself is incredible loud after you pushed the button. How can I change the volume of the loudspeaker on the doorbell? No solution in the manual.
Thanks, I will give it a try when I'm around the doorbell againConnect to the db11 with the tool IP config and see if that gives you the option to adjust the speaker.
Great review. Your work is appreciated That said, this doesn’t sound like the best use of a mallard.Courtesy of Andy @EMPIRETECANDY today we have the DB-11 Video Door bell.
It will be available here soon: Empire Technology Co., Ltd - Small Orders Online Store, Hot Selling and more on Aliexpress.com | Alibaba Group
Video
Video Compression H.264
Image Sensor 1/2.9” 2MP
Lens 1.9mm
Angle of View H:140°
Day/Night ICR, 5m
Audio Audio Compression G.711
Audio Input Omnidirectional Mic
Audio Output Built-in Speaker
Bidirectional Talk Support Dual-way Bidirectional talk
Operation Mode Keypad Single Mechanical Button
Motion Detection PIR, 5m, H:120°
Network Wi-Fi IEEE802.11b/g/n, 2.4GHz
Ingress Protection IP55
Memory Slot Micro SD, Max 64GB
Installation Surface
Material Plastic
Power AC16-24V/DC12-24V
Power Consumption Stayby<3W, Work <5W
Working Environments ﹣20°C~+50°C
Relative Humidity 10%~95%RH
Dimensions 119.0mm×47.0mm×29.0mm
Weight 0.30Kg
Here is the manual:
Here is the spec sheet:
We are off to a better start than with the Db-10 video door bell. Keep in mind, So far this is based off of the DB-11 residing about 3 ft from my wifi router.
As I don't have a traditional door bell, I'm testing this using a 24vac transformer.
The following works as it should:
Here's where things go a little south. When answering a call on the phone, out of 10 test calls, 3 times I received the error that "Audio Failed". Video still streamed.
- Adding to the Lechange app.
- Manual Video viewing: both SD and HD
- Audio during manaul view-talk and listen.
- Audio Quality from the door bell speaker is MUCH better than DB10....still very low volume.
- No batterys!
- Motion detection alerts, with actual recorded video.
- SD card is recognized and can record to the card (same exact SD card the DB10 still doesn't recognize)
- Pressing the door bell button, alert comes to phone.
- Pressing the alert on the phone, brings up video from the Db11.
We'll see what happens when I move this out by the front door.
Camera porn:
Mounting Bracket
View attachment 31418 View attachment 31419 View attachment 31420 View attachment 31421 View attachment 31422
Db 11 on the left.
View attachment 31423 View attachment 31424
Video
Lens 1.9mm
Day/Night ICR, 5m
Material Plastic
Weight 0.30Kg
Here is the manual:
- No batterys!
Camera porn:
Mounting Bracket
Db 11 on the left.
Sadly no solution found yet.I have the same issue. I would like to disable the sound on button press (on the video doorbell) but lowering the volume would work for me too. Have you found a solution yet?
Or can we maybe just replace the sound file on the doorbell somehow?
Factory reset it using the switch on the back https://dahuawiki.com/Doorbell/DB11/Factory_ResetThe firmware on my DB11 has updated to V1.000.R.20211207 and the video now seems overexposed. I tried to manage with the config tool and now I am getting a message that it is not supported yet. Configtool is updated to latest version 5.000.0000001.8 Any ideas?
