Many thanks to @actran and @looney2ns. How are PTZ "pre-sets" handled within the BI console?
BI cannot SET the presets. you do that in the cam interface. BI can CALL the presets, tho. and can do so on a schedule or based on events, etc...
I am sending significant gratitude vibes to both @actran and @looney2ns View attachment 33377
Can you guys tell me how to use scripting to control my Dahua PTZ camera...something like this?...
If Cam1 is triggered by motion the the PTZ goes to preset #4
If Cam2 is triggered by motion the the PTZ goes to preset #7
If Cam3 is triggered by motion the the PTZ goes to preset #5
BI does have a JSON interface that allows external things to interact with it. I have no idea how current this document is, but the PTZ section looks like it lets you point a camera to presets.So I would image something like this isn’t possible within Blue Iris, but is there an external scripting language that is supported by BI?...
If Cam1 is triggered by motion then PTZ goes to preset #4
Wait 5 seconds
Go to preset #7
Wait 5 seconds
Go to preset #4
Wait 5 seconds
End
looney, how does this camera with starlight, compare to the other one you tested, the DH-SD1A203T-GN?
This is made by Dahua I believe.Which is the model number for the Starlight? I can't find that Ti version, that you guys are talking about.
I have this camera, and it functions just like a 5231 with PTZ added, but no IR. I bought this a couple of weeks ago, have it mounted and functioning, but right now don't have the time to do a full review. It is currently mounted in an area that has about half IR external lighting only. The darker area still has very good night time picture quality.Thanks.
This model is brand new? Only Andy sells it?
