MrMark
The 22204T-GN isn't Starlight, the 22204TNI is the Starlight version.
Hi,
Where can I see/buy the 22204TNI ?
That one is US model, international one also have. Just released.Hi,
Where I see/buy the 22204TNI ?
The starlight model still not ready for the stock, right now we have just normal ONE.@EMPIRETECANDY How to order them ?
Perhaps you can send me a aliexpress invoice for 2 ?
International modell would be fine.
No, the cameras will be installed, and hooked up to the wiring panel.By the wya, You are using configtool to make the upgrade?
Here is sample video. Sorry for the bouncing daytime video, been very windy and my test rig is paying the price.
I am pleasantly surprised at how well it holds it's own at night.
The zoom into the mailbox is with digital zoom turned on and used.
There is a 5231ZE just to the left of the cam with it's IR on.
Plus the post lamp with 7.5w of LED light.
No, you have step up to the pro series.Will this camera track or PTZ on the action? If not which PTZ cams offer this feature? I recall an axis (sp?) cam about 2 years ago that tracked the action remarkably well.
I'll be the guinea pig for the new SD59225U-HNI PTZ.Have you tested any of these pro series PTZ cams? Do you have a model number in mind?
Thanks!
SD22204T-GN with special booking, sd22204t-gn on the market is normal one.What is the part number for the international model? Do you have any idea when it will start shipping?
new one is starlight. .Thanks. Is there any advantage to the new version of SD22204T-GN over 22204TNI ? Or vice versa? I wonder why Dahua wants multiple part numbers for the same camera...(?)
Yes sir, as far ptz goes it works, just using find inspect worked for me.@looney2ns is there a method by which Blue Iris can control the SD6CE245U-HNI camera?
Yes. Thanks! I understand that. But I'm wondering how one controls the pan, tilt, and zoom functionality from withing the Blue Iris console.
