R0 / DS-2CD2x32 BrickfixV2 brick recovery and full upgrade tool - enhanced.
Joined
May 8, 2015
Messages
14
Reaction score
2
The last time, many years ago,I wanted to update the cams and i bricked them.
There is no reason that It will work now !
Do i have to try ? ;-)
When I read the forum, I see other people who have working cameras and who use your method, why?
alastairstevenson
Staff member
Joined
Oct 28, 2014
Messages
15,973
Reaction score
6,798
Location
Scotland
Possibly to convert CN cameras running hacked firmware to EN so they can be fully updated with the stock EN firmware.
It depends what was done to the cameras. The method works OK and has been used extensively.
Joined
May 8, 2015
Messages
14
Reaction score
2
I don't understand your answer.
When you look at this post
YOU said that the update will brick the camera !
This is what happened with my cameras.
So, what do you think that i have to do ?
alastairstevenson
Staff member
Joined
Oct 28, 2014
Messages
15,973
Reaction score
6,798
Location
Scotland
Yes, updating a CN camera with stock EN firmware will brick it, unless the BrickfixV2 method is used to convert the camera to EN. After which updates can be applied normally.
What you need to do depends on whether your camera is a CN model and whether it's currently running hacked firmware.
As requested, what's the cameras full serial number and model number?
Joined
May 8, 2015
Messages
14
Reaction score
2
My model and serial number is DS-2CD2432F-IW 20150127CCCH502125217
I don't think it's a hacked firmware because i never updated it.
So, i have to convert my CN camera in EN camera. After i will be able to update the cam with the stock EN firmware.
If yes, can i do that with another method ?
alastairstevenson
Staff member
Joined
Oct 28, 2014
Messages
15,973
Reaction score
6,798
Location
Scotland
Ok, so thats certainly a CN camera.
After conversion to EN the stock firmware can be used.
Back then, the CN cameras were shipped with hacked firmware. If you've never updated the camera, you'd never know.
alastairstevenson
Staff member
Joined
Oct 28, 2014
Messages
15,973
Reaction score
6,798
Location
Scotland
Can i use another method to convert this cam in EN ?
The conversion requires that a couple of bytes in mtd6 be changed.
This could be done by a flash read, modify, and re-write.
But I don't understand why you can't change mtd6 by the documented method - what's the problem with doing so?
Joined
May 8, 2015
Messages
14
Reaction score
2
Honestly, i don't know what you are speaking about.... ;-)
I'm a noob.
I'm going to check out this mtd6 thing
It's the step 9 of your guide ?
Oleglevsha
Joined
Jan 25, 2015
Messages
299
Reaction score
77
Location
Россия г.Волгоград
if your camera is still loading and working
the easiest way is to download and install the service firmware from this site the firmware will change the camera on its own
Sammy1970
Joined
Mar 4, 2024
Messages
1
Reaction score
1
Location
AU
In case it hasn't been posted previously DS-2CD2632F-IS dev type 1098 is correct and the steps above worked perfectly! Thank you very much for your work!
janz
Joined
Jan 12, 2024
Messages
4
Reaction score
2
Location
Finland
Hi,
Seems like there has been lately discussion of DS-2CD3132-I with version 4.0.8 build 150401 being in recovery mode. SADP finds the camera with IP 192.168.1.64 but this is not accessable with anything. It responds to ping thou.
Some backgroud as alastairstevenson required earlyer from similar situation.
1. Got this of our customers SER trash and have no idea of the passwords as nor do they.
2. They got new ones because of them being old and not having access to them
3. No idea if they are Chinese or what
This is the state i got it, is there anything that can be done or is it a lost case? Didn't seem to find any solution to reset the situation.
BR.
alastairstevenson
Staff member
Joined
Oct 28, 2014
Messages
15,973
Reaction score
6,798
Location
Scotland
This documented BrickFix method can be used for brick recovery of R0 series cameras, and conversion to EN of CN cameras.
But it's fair to say that R0 series are quite old now, and don't provide good performance compared with current models.
janz
Joined
Jan 12, 2024
Messages
4
Reaction score
2
Location
Finland
Aah, was to tired when typed that, sorry. Yea, i tryed that metod also, i cant get the tftp to reqognize the camera. I know they are old, i have couple never models but this would fit perfectly in my garage :D
And further stuff that i have done.
  • Firewall off
  • ip set to 192.0.0.128
  • ip set to 192.168.1.128
  • only the camera and pc in same poe switch
  • Downloaded all required stuff again in new folder
And probably alot more that i can't remember anymore
edit
Thank you alot alastairstevenson for all the work you have done for this community. Awesome that people with the skills have time to help morons like me :D
alastairstevenson
Staff member
Joined
Oct 28, 2014
Messages
15,973
Reaction score
6,798
Location
Scotland
On the R0 series hardware - activating a PoE handshake and enabling the ethernet interface can take long enough that it clashes with the short time that is allowed for a tftp updater handshake to be attempted.
If you have one, maybe try a 12v adaptor to power the camera instead of the PoE switch, with the camera in a non-PoE port so that PoE power isn't featured.
janz
Joined
Jan 12, 2024
Messages
4
Reaction score
2
Location
Finland
Thx mate. I don't have a adaptor but i can try a poe injector if that would be faster.
Top
