- Nov 23, 2017
- 467
- 193
Yeahbut does it leave piles of molten plastic from burning a hole in the front bumper?
Congrats!
That's v4 with the 48w and the bat signal, it burn the bat wing shape onto the cars
Congrats!
Much to my wife's chagrinThis guy doesn't need a Hobby. I think he's found it. Good Job dude.
So slight hicup with the laser (guess the laser is v3)... The AliExpress vendor actually don't have any in stock. And AliExpress don't send me mail when I get a message on their platform so wasted like 5 days between not knowing about it and asking the vendor what they have(no laser at all....).
Ended up ordering a 10w version off eBay which just got shipped. Will see if it's actually anything closed to what it claims to be.
The lens for the lonnky v2 is clearing US custom but at v1 4w vs V2 6w I'm not holding out much for much improvement
I went to build the laser. It sucked.
Did with a 660nm red one because it was easier. Beam pattern was nasty. I had some holographic glass lenses to do beam spreading and refocus but, honest, it was just awful all around.
I should give it a go, new lenses came in but I didn't have time yet to do anything with them.
Edit: I mean I built the laser, not the vendor stuff you used. Which one did you end up going with? For the cost it looks like it would have enough power to hit what I needed at night.
660nm is in the visible red spectrum, better to use a white light at that point. It also depends on the wattage of the output, regular laser pointer are in the mw range where did illumination (not collimated in to a laser beam) we are in the 1-3w range
I did a review here with a ebay link for what I brought. Contact the seller for customization option. I actually just ordered the 9 chips laser (supposed to be 15w) with 7 degree lens. It's in transit from China so I will update once I get it
VCSEL IR Laser 850nm illuminator for long distance spot IR 250+ ft
6/3 Update So.... the 9 laser chips illuminator arrived today, it works and it is good! run lurk warm (not hot at all, i can hold forever) even in my chilly basement but since it will only be on at night with no Sun, that should not be an issue. Same great tight and bright as the 4 chips one...ipcamtalk.com
That's awesome!So.... the 9 laser chips illuminator arrived today, it works and it is good! run lurk warm (not hot at all, i can hold forever) even in my chilly basement but since it will only be on at night with no Sun, that should not be an issue. Same great tight and bright as the 4 chips one. I was able to knock down my gain to 25 with 1/1000 shutter (enough for my head on application) and 100% open iris. It seem to be a case of diminishing return though, upping the shutter to 1/2000 some plates start to become dimmer than I would like. seller claimed customized to 15w output, killawatt show 19.5w draw at the wall
I bought this IR illuminator which has the 940nm wavelength light, invisible to the human eye.
There are plenty of folks using the cheapo Amazon IRs and they seem to work fine. Maybe not as focused as the Axton 10' units but still workable.What was the final solution here @Bitslizer I don't want to pay for the $300+ axton either
I saw the new di20 from tendelux limited reviews...There are plenty of folks using the cheapo Amazon IRs and they seem to work fine. Maybe not as focused as the Axton 10' units but still workable.
