- Nov 23, 2017
- 467
- 193
The z12 is actually acting like very nice IR illuminator for my backyard lolBetter off turning off the IR on the camera (no spiderwebs) and build a discrete housing for the Axton.
I have one location with bullet cam IPC-HFW1831EP (2 Emitters) and have constant spiderwebs. All other locations multiple external Axton Emitters and all IR turned off on cameras no spiders ever.The newer cams without the ring of IR LED are less prone to spiderwebs. My Z12 has never had a spiderweb problem, nor any of my other Dahua cams. As always, YMMV.
Have some family plan tonight so I may miss the prime traffic hour in the early eveningWow that last one really tightens up the IR - horrible for overview but perfect for LPR.
Can't wait to see tonight's results!
Family help usually mean the more they help the busier you get, that's mainly due to the kids are young... looking forward to when the boy is older and I can actually teach "dad" stuffFamily plan means they drive up and down that spot to help you align up the IR light![]()
I know I need to mount the camera higher as I think a lot of the issue I'm suffering from are lens flare due to that section of the road is a slightly upward incline, shining the light into my camera. The lens flare hurt contrast a lot. For the IR emitter I can get slightly better horizontal angle closer to the ground vs hanging out the second story window where the horizontal is not as good but I can get higher degrees of vertical angle more parallel to the camera. Eventually I should be able mount them in a better place but not about to toy with a 22ft ladder tonightThe closer in height it is to the area you are trying to capture, the easier the alignment LOL. But could a neighbors fence or van in a driveway block it in the future?
I would think at the distance you are trying to cover, the higher angle and offset from where the camera is could end up not reflecting back as much, but at the same time I think you don't need that much based on your other captures.
