bozoreefer
They have been working fine, you just need to make sure to turn off ONVIF authentication
thank you!
thank you to @wittaj as well for the review
Just purchased. Should be arriving later today.
Here is another example of settings for the T5442-Z4-S3.
		OK, I guess I didn't think of distinguishing the objectives of the different cameras. For the 5442's in my driveway, I think I would want to focus on IDENTIFY a person coming toward the house. I did not post a video of that but I took one i think and it was pretty good. So maybe I don't need to tweak the settings on the driveway 5442 then. Like you always say, different settings may be needed for each camera to meets the objective i want. I didn't think of it that way.Those are not terrible.
If vehicles are your primary objective, I would force illuminator to manual and blast it at 100. The camera needs more "light"
Drop NR to no higher than 40
Consider a fixed shutter speed instead of a range.
Gotcha.. Yes the Smart IR works well as people walk up the driveway at night.. I can IDENTIFY well which I think is my goal for those two driveway cams as they approach the house. The "overwatch" camera that is higher up prob not much real use at night since its zoomed all the way out. Its purpose is during the day to basically watch the front of the home (driveway, yard, street and such). I'd like to get one of those 4 cameras to focus on getting as clean of image of a moving vehicle as possible. Make sense? You think the Z4 is the best for that? I still have 50% zoom to go but I am trying to get it to monitor that portion of the yard before the sidewalk as well as passing vehicles so I rally don't want to zoom in anymore if I can prevent it.Yeah, the Smart IR would be good for someone walking up towards the camera, but if the primary objective of the camera is an object 15 feet away or more, Smart IR will usually be ineffective and make the image worse as it adjusts the IR and then the shutter speed and other things change - it needs to be blasted with as much light as possible.
Makes sense. I’ll zoom that Z4 in tonight and see what sort of image I can get with it. I may have enough light to run my overview 5442 in color to try to capture some color images since I have enough IR cameras to get what I need from them. What basic settings do I need to set for that to run color at night to see if I can get a decent color pic at night. I never thought of forcing that overview camera to color at night. Thanks again.Yes I think the Z4E is the best for that purpose.
Obviously everything is a compromise, but you need to decide the primary goal of the camera and if it captures anything else, just a bonus.
This is my Z4E at 1/500 shutter setup to get clean captures of vehicles. I have an overview to capture color.
I could zoom this out to capture people walking on the sidewalk, but then I will lose detail on both.
So I zoomed in all the way and will get a clean capture of the upper body and face of someone walking by on the sidewalk or in the street.
My overview will capture the other aspects - color, where they came from, etc.
OK. Makes sense. I’ll try running the slower shutter for now.If you have other cameras to capture the details, then you can run a slower shutter on an overview to get color.
So two schools of thought are run the camera in color with the fastest shutter you can that it still works in color. Might be 1/30 or 1/60.
Or add a true overview cameras like a 180 camera and use it on default settings, recognizing that you won't get IDENTIFY, but you will get color.
Thanks for the suggestions. I can run another cable which I knew my dumb ass should have done in the first place...Stupid mistake.Best is to run another cable, but many of us have used this with great success:
Some have been able to get this one to work with an NVR as well, but the above one is probably better for an NVR as it keeps each camera on its own port.
Oh ok... I wasn't sure if people thought that was a good enough image or not...Thanks for your input! Appreciate it,You could try some of the compensation settings but that typically has some side effects. That looks pretty good to me. I wouldn't bother with it. I was expecting to see the typical bright background and very dark face but yours isn't bad. I can stop it at any point and get a clear identifiable image. If you do add compensation, just do it as little as you can.
