LPR setup help
Quick question for all you smart people.
If I were to purchase another Poe+ or poe++ swtich to run 2 switches. Would you have the ethernet cable from the NVR to the main POE switch (in this case the trendnet) and then another ethernet cable from the trendnet to the second POE switch?
Now for IP addresses and all that, would you change the IP address to the same range as the first one (say it's 10.3.3.3) or change to a different address such as 10.4.4.4?
Thank you much
I have four POE switches. Two in a rack in my IT closet, one in the garage, and one in my first-floor office.
In the attached diagram, the POE switches are in RED. I run dual NICs in two PCs and two subnets, one for the cams and one for everything else. You could think of the PI PC as your NVR and ignore the Office PC.
Hope this diagram helps.
Reactions: Timokreon and RyanB
So basically the last 3 in the IP address should be different, everything else the same. Thank you!
As long as you are also separating out your surveillance network whether that be physically, different switches on different LAN configs, dual homed (2 Nic's) as @samplenhold is using OR through VLAN's (along with firewall rules in place of course). Just making sure you weren't setting up a LAN with everything flat (same subnet etc across the board).
Perhaps progress on the new light. Happened to catch a crew taking GPS measurements and looking in man hole covers around the area the new pole is to be installed.
I'm thinking they're coming up with a way to get power to the new pole.
I thought they were just going overhead, but now guessing underground.
Progress regardless. :)
So your saying you may have a new street light by Christmas? :p:p
