Looks all correct. Below are all the custom models that are installed with Object Detection (YOLOv5 6.2)
Once you install the License Plate Reader module use the below settings. Also all cameras will be running the license plate detections so cameras you do not what to run the license plate detection needs to have alpr:0 in the Custom Models box.Yeah just thought I'd see a comma after "acrionnettv".
Just confirming for the license plate camera it looks like I don't need to add "ipcam-" in front of the license-plate for the custom model name?
Remove space, uncheck Use main stream if available, and change To confirm to person,vehicleJust to confirm, here are my non LPR cameras:
And the LPR Camera:
And the master AI settings:
Look correct?
Uncheck Override serverHmmmm...still not getting any alerts. Have a guy doing some work right now on my driveway, but nothing is triggering...
View attachment 181454View attachment 181455View attachment 181456
View attachment 181458View attachment 181459View attachment 181460
Leave the LPR camera Use main stream if available checked. For DoNotCancel it is best to have it in all your cameras so the AI will analyze all the +real-time imagesJust to confirm, same changes to the LPR camera? I.e., do I check or uncheck "Use main stream if available" and do I insert "DoNotCancel"?
Can you only have DoNotCancel in the To cancel box? I also have "bus" from when it was recommended a long time ago.Leave the LPR camera Use main stream if available checked. For DoNotCancel it is best to have it in all your cameras so the AI will analyze all the +real-time images
All you need is DoNotCancel, it can be anything as long as it is not in the model you are using.Can you only have DoNotCancel in the To cancel box? I also have "bus" from when it was recommended a long time ago.
Is there a canceled alert at the time it should alerted you. If so open the saved AI analysis details to see what happened.Hmmm...next issue:
1. None of my cameras are trigging alerts to the BI app on my phone.
2. My front door camera doesn't trigger anything, just had my son walk in front of it (And had the profile set to "at work"). It also, weirdly, is the only camera without its own Alerts directory.
Settings below:
View attachment 181518View attachment 181519
View attachment 181520View attachment 181521
View attachment 181522View attachment 181523View attachment 181524
Also run a test using CodeProject.AI Server Explorer to make sure CodeProject.AI is working.Hmmm...next issue:
Settings below:
If you want Blue Iris to mark the alert as a vehicle then leave itThanks, I must have copied the "pass section B" or whatever that is called over to the FrontDoor camera which was causing it. Fixed.
Only remaining issue is I'm not getting notifications to my BI app. But will look into this. BTW, do I need this blurb in this field?
