Did you place general.pt file in the below folder
Yup. Can't figure out why I am getting zero alerts.
What is BI log and AI analysis details showing for a canceled alert
Where do you get Mike's license plate model for DS?
The license plate model just detects a license plate in a image and the lplate_char.pt model detects characters A-Z and 0-9. the two models are used with DeepStack ALPR that a made.What is "lplate_char.pt"? Do you have to have that for the license plate model to work?
Also, if you use license plate model on a cloned cam should you put "objects:0,general:0" in custom models.
To see the AI analysis details go to the Canceled alerts and on any canceled alert hold down the CTRL key and double click on the canceled alert. This will open the AI analysis details for the canceled alertHmm...looks like not responding and timeouts?
Where can I find the .dat files or AI analysis details to drop into the AI tab?
It looks like DeepStack Custom model is not running. Try rebooting the PC to see if this helps. Another option is to switch to CodeProject.AI
I have not had issues with running it, some users have had issues with install it. When switching the custom models name changes by adding ipcam- to the beginning of the file name so general.pt is now ipcam-general.pt. They just release v2.3.2, the link to this version is below.Is it as reliable as DS? Yes I realize the irony in that question right now..
Is it easy to switch?
Mike,I have not had issues with running it, some users have had issues with install it. When switching the custom models name changes by adding ipcam- to the beginning of the file name so general.pt is now ipcam-general.pt. They just release v2.3.2, the link to this version is below.
The link triggers a downloadMike,
This link takes me to a new tab in Firefox, but a completely blank screen. Will the link trigger a download, or take you to a new page for 2.3.2?
Thanks. It is working now. Don't know why it didn't before.The link triggers a download
I would be interested to know if you get this working. I suppose if you had a lot of non-vehicle motion in front of your cameras (e.g. lots of foot traffic) it might make sense to cascade the detection.Is there a way to only analyze with Delivery.pt if a vehicle is detected? I tried doing this by cloning cameras. One clone i set to trigger on vehicles which them triggers the group that the other clone is in which is configured for delivery.pt. Is what I am after worth it? I would rather not send multiple false alerts through delivery.pt unless a vehicle is actually detected.
Bump..is there an install guide somewhere and or an easy way to move from DS to Codeproject? Assume it’s not as simple as uninstall DS and install CP?Thanks, presumably I just uninstall deepstack and then install this? Are there settings different from teh ones I use currently in deepstack, and/or an install guide?
