I have the same problem , after checking hikvision site i found anew firmware version to my device 7216HUHI K2 . After i upgrade my newfirmware version problems started. i can not recover from tftp and a can not interrupt bootloader, commands not working, onlyThis was the key, I solved the problem, my DVR is back to live again. Thank you anyway for your help, you really helped me a lot.
I also had the same problem, I updated and now I can no longer access the normal menu. wait Antonio1 I did not understand if he solved ..I have the same problem , after checking hikvision site i found anew firmware version to my device 7216HUHI K2 . After i upgrade my newfirmware version problems started. i can not recover from tftp and a can not interrupt bootloader, commands not working, only
HKVS $ .
how you solve the problem ?
I do not understand, have you got the firmware wrong too?If you have a OEM nvr that came with 4.XXX firmware. and wish to flash it to hikvision firmware. now out of luck. no longer work.
Presumably that's on the VGA/HDMI interface.After restarting nvr is a black screen no menu.
make sure you turn off all firewall and before open tftp. second, set pc ip to 192.0.0.128.i can connect with putty using ttl adapter. Booth using CTRL-U. i set the ip address of 192.0.0.64 and have tftp open with 192.0.0.128. Firewall turned off... No connects to tftp. i am lost. any suggestions?
It's not very clear from the image - but it looks like the device may have the serial console on the RS232 interface via the DB9 socket on the back panel.i cant find the ttl port on my main board
I have the same... dvr - DS-7208HUHI-K2 , after firmware upgrade no user to choose, so can't login. SADP don't see it, but there is answer to ping via pc... I am tryging fix it second week in free time...
I can connect via putty, but there is no response to keyboard , can't stop booting via ctr+U, and can't put any command after dvr is up. I was looking for putty settings, because I am not only one with this problem ( no keybord response in putty) but I hope that somebody will help hereIt looks similary to Gregs53 problem. thx
Connect to the serial console and reset the configuration to default values.Any suggestion to recover it ?
tnx for fast replyConnect to the serial console and reset the configuration to default values.
Usually a 4-pin connector, ZH JST 1.5mm type.suggestion to find on board
