That is the correct firmware. You must use Internet Explorer, not Edge in IE mode, but plain Ole Explorer.
Otherwise you may not see all the options.
Thanks, I saw the 15 second timer issue but didn't know the entire menu wouldn't show up. Guess I should have kept that old PC around because nothing I've got has IE and it seems you can't even download it. I'll keep probing around, but thank you again for letting me know this is the right firmware. Now I have an IE issue.That is the correct firmware. You must use Internet Explorer, not Edge in IE mode, but plain Ole Explorer.
Windows 11 still has Explorer-- it is well hidden, but can be pulled up. There are threads about how to do it.Thanks, I saw the 15 second timer issue but didn't know the entire menu wouldn't show up. Guess I should have kept that old PC around because nothing I've got has IE and it seems you can't even download it. I'll keep probing around, but thank you again for letting me know this is the right firmware. Now I have an IE issue.
Well I found an old PC I'd forgot about, has Win7 and IE11, logged into the camera but still no luck. The smart plan and other menus still aren't there. Should IE 11 display those menus under Win7?That is the correct firmware. You must use Internet Explorer, not Edge in IE mode, but plain Ole Explorer.
That is simply brilliant, I love built-in work-arounds like that. In my case under both IE11 on WIN11, and using the hidden work around I still don't see the menus required to enable auto-tracking. Specifically I'm looking for the Smart Plan and Deep IVS menus under Events.......Which is leading me back to suspect the firmware version is improper.Windows 11 still has Explorer-- it is well hidden, but can be pulled up. There are threads about how to do it.
How to Get Internet Explorer Back on Windows 10 and 11 In 2023
If Internet Explorer is no longer working on your PC, you can follow these simple steps to get it up and running again!nosamu.medium.com
My camera info is:Which hardware version do you have, the latest ones do not support auto tracking.
On my camera under PTZ I have only a Function sub menu.I'm not in front of mine now but what shows under PTZ tab - is that where smart plan is
Have you tried setting the cam back to factory defaults, then setting it back up from scratch?I bought it from EmpireTech in April 2022.
I haven’t tried that yet, but that was the next thing I was thinking. but I held off because I did hear back from Andy and his initial response was that it should work and he sent me the PDF showing how to set up auto tracking. I had already been through that, and I read every post in this forum before coming to my dead end.Have you tried setting the cam back to factory defaults, then setting it back up from scratch?
Thank you so much for your help! After logging in via team viewer you were able to solve the problem quickly. All it needed was a full factory reset, but then you helped me set up the auto tracking settings to optimize it for my location and I really appreciate the time and effort you put in to help me. You are a superstar!I can have a look via Teamviewer if you wish pm me ID & Pass
Your intuition was 100% correct. LJW2K connected via team viewer and after seeing everything looked appropriate, he did a full factory reset and those two menus suddenly showed up and auto tracking is fully working now. This is really a fantastic camera. I should’ve bought a second one when I had the chance.Have you tried setting the cam back to factory defaults, then setting it back up from scratch?
Do you know if the sd49425XB-HNR is the same as a 49425XBNR? Im thinking the 49425XBNR is the USA model number. Do you think this firmware would work on the 49425XBNR?Compatible with the below listed camera's
DH-SD5A445XA-HNR
DH-SD59425XA-HNR
DH-SD6AE233XA-HNR
DH-SD49225XA-HNR
DH-SD6AL445XA-HNR
DH-SD6AL445XA-HNR-IR
DH-SD6CE445XA-HNR
DH-SD1A404XB-GNR
DH-SD1A404XB-GNR-W
DH-SD59432XA-HNR
DH-SD6AL233XA-HNR
DH-SD65F233XA-HNR
DH-SD6AL233XA-HNR-IR
DH-SD6AE433XA-HNR
DH-SD5A425XA-HNR
DH-SD49425XB-HNR
DH-SD49425XB-HNR-G
DH-PTZ1A225-HNR-XA
DH-SD59232XA-HNR
DH-SD5A225XA1-HNR
DH-SD5A432XA-HNR
DH-SD5A232XA-HNR
DH-SD50432XA-HNR
DH-SD50232XA-HNR
DH-SD52C432XA-HNR
DH-SD52C232XA-HNR
DH-ECA-7A1425-HNR-XA-F
DH-ECA7A1425-HNR-XA-F
DH-SD6AL433XA-HNR
