Dahua SD49225XA-HNR Auto Tracking Enabled Firmware.
For whatever reason they issue a PAL and a NTSC firmware, but it is a simple toggle in the menu to change it, so it doesn't matter which one...BUT...we have given you enough caution that you are playing with fire and may end up bricking the unit or it goes into Chinese.
Reactions: JDreaming
I've been noticing that the firmwares are always bin files, however there are multiple firmware versions and inside said versions there are multiple bin files. Is there somewhere that explains the breakdown?
For example, this camera version apparently has 3 firmware files, with no explination.
Then inside of the file are mulitple .bin files
I'm guessing first file is the Chinese version, and 2nd and 3rd one is MutiLang supported Pal and NTSC version.
The last part of the firmware is probably the date it was created. 210705 = 2021-July-05.
oh man, the seller is making some fraud, that is a SD49225T-HN, not a SD49225XA-HNR. Don't update the AT fw again. Will brick it. Just use that fw comes with.
I did something to it, flashed a firmware wrong or something, Started looking like this:
I was also restarting and spinning up every 3-5min.
On one of the reboots i quickly did a firmware update using the bin file mentioned above for PAL (DH_SD-Mao-Rhea_MultiLang_PN_Stream3_IVS_V2.800.0000000.6.R.210705)
I did not get autotracking, but it now has heat map. Not sure how useful that is... or if it is even usable in blue iris or the online config portal.
But the good news is that it all seems to be back working. So i will not be touchig it from here.
Device Type: SD49225T-HN
System Version: V2.800.0000000.6.R.R4.2510.9A.NR, Build Date: 2021-07-05
WEB VersionV3.2.1.1082304
ONVIF Version: 18.12(V2.4.5.826858
PTZ Version: V3.02.93.RHNZ_170518_22722
Module Serial Number: 5H083B6PAX00397
S/N: 5I09F9HBG2A6346
Security Baseline VersionV2.0
I wonder if i could dispute the sale with ebay for improper listing model. Is this model cost much less then the
SD49225XA-HNR?
SD49225XA-HNR?
hmm, that is bad, right now that SD49225T-HN is around 100-150usd worth. Too old, pic not as good as the 49225xa. The 49225xa also have 4 versions from they release.
Hello, help me, I need a firmware with auto tracking on dh-sd49225xa-hnr-s3!?
ТипDH-SD49225XA-HNR-S3
Версия системыV2.812.0000015.0.R, Build Date: 2023-02-28
WEB модульV3.2.1.1393370.L5.2531.UN.NR
ONVIF версия21.12(V3.1.0.1235054)
PTZ v.V2.401.0000000.89.RHNAP_201119_36766
S/N8G061AAPAJD916B
Версия алгоритма1.0.2
Базовая версия безопасностиV2.1
S/N8G061AAPAJD916B
Not gonna happen - the S2 and S3 chip will not accept autotracking firmware.
[ЦИТАТА="wittaj, сообщение: 770278, участник: 75149"]
Не будет - чипы S2 и S3 не будут принимать прошивку с автотрекингом.
[/ЦИТИРОВАТЬ]
привет, установил s2 (DH_SD-Prometheus_MultiLang_PN_Stream3_V2.800.1341000.0.R.200312) и все нормально, а на s3 не устанавливается!
You need to purchase an older 49225 with a built date prior to 2020
OR
Buy a camera that supports autotracking.
Dahua removed autotracking from the 49225 sometime in 2021 and it is now being built with a different chipset that cannot run autotracking.
[ЦИТАТА="wittaj, сообщение: 770332, участник: 75149"]
Вам необходимо приобрести более старый 49225 с датой выпуска до 2020 года.
ИЛИ
Купите камеру, которая поддерживает автотрекинг.
Dahua удалила автотрекинг из 49225 где-то в 2021 году, и теперь он построен с другим набором микросхем, который не может запускать автотрекинг.
[/ЦИТИРОВАТЬ]
и на v2 812 0000009 0 r l5 2531 ед. номер, дата постройки: 2021-08-26 ?
OR
dh-sd49325xa-hinr-s3 v2 812 0000009 0 r l5 2531 un. nr, build date: 2021-08-26 v3.2.1:1109744 20 06(v2 9 0. 970440) v2.401.0000000 89 rhnap 201119 36766 8g061aapajd916b 1.0.2 v21 ?
Hi, I have a DH-SD49425XB-HNR camera and I have a problem with auto tracking (this option is not in the software) do you have a firmware version for this camera to activate it?
As was mentioned, the newer chipsets will not accept the autotracking firmware. You can try to update it and it will either not accept it or will brick the unit.
What version firmware do you have? Keep in mind there isn't an "autotrack" slider or selection point, it is just native to how you set up the Smart Plan and IVS rules.
There is not a button for AT. It is part of the setup.
Make sure you are using Internet Explorer - not Edge or Chrome with the IE tab. The Dahua PTZs need Internet Explorer or your track time will default to 15 seconds regardless what you put in.
You need to set up a preset.
Then you need to set-up the Smart Plan with Deep IVS for the presets you want to track.
Then select the object filters you want.
Then go to Deep IVS Rules Config page and you should see Track Time under alarm and Tracking Target size slider.
When setting up IVS rules, I strongly recommend you use intrusion box with appears and crosses instead of tripwire. And less is more. One IVS rule.
Leave min size as 0,0
Make sure that Motion Detection and Smart Motion Detection are turned off.
I repeat, make sure Motion Detection and Smart Motion Detection are turned off LOL.
If you do not have the above screen with the Tracking Target Size, then you have a version without autotrack.
Or return it and buy one that comes with autotracking already and then do not update the firmware:
Besides the auto-tracking-- the quality of video coming out of these is fantastic. it's only 2MP, but it is the best quality image of any cam I have.
I do keep motion detection on so that I can record alerts for the neighborhood deer that move through, as well as cats, dogs, coyotes, etc...
My firmware version:
DH-SD49425XB-HNR
V2.810.0000017.0.R.P9.2522.UN.NR, Build Date: 2020-11-23
WEBV3.2.1.984015
ONVIF19.12(V2.8.0.923968)
PTZV2.401.0000000.64.RHNZ_200219_34642
So I suspect it's possible to run auto-tracking, but this firmware version has been removed, so I need the previous firmware version.
From reading the above it seems my PTZ is eligible for the auto tracking firmware, yet it did not come with that ability. It has no smart plan nor deep IVS menus. I see there were links posted to firmware but they are all invalid now. Can someone point me to the proper auto tracking-enabled firmware if it's still available?
Device Type SD49225XA-HNR
System Version V2.800.1341000.0.R.P9.2520.UN.NR, Build Date: 2020-03-12
WEB Version V3.2.1.819501
ONVIF Version 18.12(V2.4.5.729857)
PTZ Version V2.401.0000000.64.RHNZ_200219_34642
S/N 7G09C9CPAJ824E6
Security Baseline Version V2.0
