What happened with the Tracking issue ??
OK, here is a police car.
It is pretty good, no?
@Arjun : question about IVS on this PTZ: I see in the manual that IVS rules (eg tripwire) are setup the same way as on my HDBW's and HFW (fixed cams), but I'm wondering what "view" you have in that setup screen: is this "the current view" or a "360°" view?
I'm asking because I have this basic question which is not answered in the manual: if you let your camera "tour" for example 180°, with at the outer left side, the back door and outer right side, a window. I would like to set 2 intrusion boxes on the back door and one on the window. I am aware that a burglar could potentially see the "tour" parcours of the camera and run "behind" it to break and enter, but the theoretical question is: can you draw IVS rules on the full "scan scope" in the tour pattern or not?
Thanks for your feedback!
CC
@catcamstar You can certainly add the IVS / Tripwires when your camera tours. You just need to go into each preset and add the IVS rules there. The preset option is in Event -> Deep IVS -> Preset # (1, 2, 3, and so on). Each preset can have its own IVS rules set. When set up to tour the IVS rules should follow as well. The presets really help a lot. The more redundancy the better and can essentially make the setup foolproof.
Wauw! This is great information! So you have experienced that when the camera is actually touring between positions, it already "analyses" IVS rules in real time?
Thanks!!!
CC
When the PTZ tours, it works in conjunction with the Presets and Auto-tracking, not with the IVS Rules. However, when the camera is in the Home Position (Preset 1), it already reacts when IVS rules are tripped and / or when other cameras in the vicinity picks up motion (through IVS rules as well).
@Wildcat_1 may be able to further elaborate on this as to whether or not it is possible to use IVS Rules when the PTZ is setup to be in Tour Mode.
And that's what I "thought" not being clear in the Dahua documentation: IVS rules on different preset positions is something "unknown", and let's face it, also very difficult to accomplish.
What about simple Motion Detection? I see in your video above "Video Detection" (second menu higher than Smart Plan) - are those MD setup's per preset?
Thank you!
CC
