Your IVS lines are too close to the edge of the frame.Can't get my new SD59225U-HNI to track reliably. It's about 25% successful.
IVS rule:
Is it just the Dahua is not very good at tracking vs the Hikvision? Yes about 25% of the time it tracks perfectly fine but most of the time it's like this.
Which camera model is this?
Ok you're still getting quite a bit of noise
Its going to be a lot of playing with settings in real time to be able to see differences.
I'd guess at going back to 1/120, make sure Sharpness is 50 or less, play with turning down Gain, and increase DNR last if either of the other 3 have a positive effect. Honestly it looks just like my older 5231 at the neighborhood entrance. Try as I might it just didnt pick up light well enough to run color at night without blur or those type of artifacts. You may be able to minimize it but doubt you'll get rid of it entirely with a 1/2.8 sensor
Are there any settings to use that minimize the recording of bugs at night? I get a lot of moths flying around and it's almost a constant recording.
I've never fooled with those settings. Is there a compendium of what all the controls do and how to adjust them?You can set up the object size, target area filtering. If you go by the default, you will get a lot of false motion events.![]()
that's good, I'll look through there. I've not see a set up manual for the software so I've just been clicking around in the dark basically.You can follow this tutorial as per the Dahua Wiki
Click on the link below,
DahuaWiki
dahuawiki.com
Focus where it discusses about Target Size, the size will determine the sensitivity and when to mark an object as Intrusion/Tripwire
