And that is my faulty start...
Uncompressing Linux........................................................................................................................ done, booting the kernel.
Checking DDR......OK
UBL Version: 1.46t(DM365)10:21:32 Oct 30 2018
Oscillator: 24MHZ
ARM Rate: 432 MHZ
DDR Rate: 340 MHZ
BootMode: SPI
Starting SPI Memory Copy...
DONE
U-Boot 1.3.6 (jerry) (Oct 30 2018 - 10:30:03)
DRAM: 128 MB
SF: Got idcode 01 20 18 03 01
In: serial
Out: serial
Err: serial
Ethernet PHY: GENERIC @ 0x05,id:221513
total gio 2
gio[22]=1
gio[25]=1
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Filename 'upgrade_info_7db780a713a4.txt'.
Load address: 0x80100000
Loading:
Retry count exceeded; starting again
Fail to get info file!
Init error!
Filename 'failed.txt'.
Load address: 0x80200000
Loading:
==>use default images
APP_OFFSET_NEW test
## Booting kernel from Legacy Image at 80007fc0 ...
Image Name: Linux-2.6.18_pro500-davinci_evm-
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1799184 Bytes = 1.7 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
XIP Kernel Image ... OK
OK
Starting kernel ...
Oscillator: 24MHZ
ARM Rate: 432 MHZ
DDR Rate: 340 MHZ
BootMode: SPI
DONE
DRAM: 128 MB
In: serial
Out: serial
Err: serial
total gio 2
gio[22]=1
gio[25]=1
Loading:
Init error!
Loading:
APP_OFFSET_NEW test
OK
Starting kernel ...
