Ncat: Version 7.40 (
Ncat - Netcat for the 21st Century )
Ncat: Listening on 192.168.254.254:5002
.2 MiB
   Load Address: 01e00000
   Entry Point:  03a80000
   Verifying Checksum ... OK
Programing start at: 0x01e00000
write : 100%
done
## Checking Image at 0309e0c0 ...
   Legacy image found
   Image Name:   web
   Created:      2018-01-15  21:24:37 UTC
   Image Type:   ARM Linux Standalone Program (uncompressed)
   Data Size:    7766016 Bytes = 7.4 MiB
   Load Address: 01600000
   Entry Point:  01e00000
Programing start at: 0x01600000
write : 100%
done
## Checking Image at 03806100 ...
   Legacy image found
   Image Name:   pd
   Created:      2018-01-15  21:25:05 UTC
   Data Size:    57344 Bytes = 56 KiB
   Load Address: 00940000
   Entry Point:  00c80000
Programing start at: 0x00940000
write : 100%
done
## Checking Image at 03814140 ...
   Legacy image found
   Image Name:   custom
   Created:      2018-01-15  21:25:08 UTC
   Data Size:    135168 Bytes = 132 KiB
   Load Address: 00600000
   Entry Point:  00940000
Programing start at: 0x00600000
write : 100%
done
## Checking Image at 03835180 ...
   Legacy image found
   Image Name:   partition
   Created:      2018-01-15  21:24:33 UTC
   Data Size:    4096 Bytes = 4 KiB
   Load Address: 00500000
   Entry Point:  00600000
Programing start at: 0x00500000
write : 100%
done
## Checking Image at 038361c0 ...
   Legacy image found
   Image Name:   kernel
   Image Type:   ARM Linux Firmware (uncompressed)
   Data Size:    1728760 Bytes = 1.6 MiB
   Load Address: 00c80000
   Entry Point:  01200000
Programing start at: 0x00c80000
write : 100%
done
## Checking Image at 039dc2f8 ...
   Legacy image found
   Image Name:   CmdScript
   Data Size:    1011 Bytes = 1011 Bytes
   Load Address: c0000000
   Entry Point:  c0001400
exce update config script start!
        set da '
tftp 0x2000000 dhboot.bin.img; flwrite; tftp dhboot-min.bin.img;
nand protect off;flwrite;nand protect on'
        set dr 'tftp 0x2000000 romfs-x.squashfs.img; flwrite'
        set dk 'tftp 0x2000000 kernel.img; flwrite'
        set du 'tftp 0x2000000 user-x.squashfs.img; flwrite'
        set dw 'tftp 0x2000000 web-x.squashfs.img; flwrite'
        set ds 'tftp 0x2000000 dsp-x.squashfs.img; flwrite'
        set dc 'tftp 0x2000000 custom-x.squashfs.img; flwrite'
        set dt 'tftp 0x2000000 data-x.squashfs.img; flwrite'
        set df 'tftp 0x2000000 fpga.img; flwrite'
        set up 'tftp 0x2000000 update.img; flwrite'
        set tk 'tftp 0x200100 hawthorn.dts.dtb;tftp 0x2000000 uImage;fdt addr 20
0100;fdt set  serial1 status ok;bootm 0x2000000'
        set bootcmd  'nand read 0x200100 0x60000 0x10000;kload 0x2000000; fdt ad
dr 200100;fdt set  serial1 status ok;bootm 0x2000000'
        setenv bootargs "console=ttyS0,115200 mem=110M root=/dev/mtdblock8 rootf
stype=squashfs init=/linuxrc"
        set dm 'tftp 0x2000000 mcu-x.bin.img;flwrite'
        save
Saving Environment to NAND...
Erasing Nand...
Erasing at 0x360000 -- 100% complete.
Writing to Nand... done
exce update config script complete!
partition file version 2
rootfstype squashfs root /dev/mtdblock8
fail to load bootargsParametersV22.txt
fail to load bootargsParametersV21.txt
Using ambarella mac device
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending throu
gh gateway 192.168.1.1Download Filename '.FLASHING_DONE_STOP_TFTP_NOW'.Download
to address: 0x82000000
Downloading: #
done
write : 100%%
done
gh gateway 192.168.1.1Download Filename 'web-x.squashfs.img'.Download to address
: 0x2000000
Downloading: *
done
Bytes transferred = 7766080 (768040 hex)
do not find BOOT_IMG_NAME!
Erasing update flag partition.
## Checking Image at 02000000 ...
   Legacy image found
   Image Name:   web
write : 100%
done
gh gateway 192.168.1.1Download Filename 'update.img'.Download to address: 0x2000
000
Downloading: T T
done
Bytes transferred = 27117355 (19dc72b hex)
## Checking Image at 02000040 ...
   Legacy image found
   Image Name:   romfs
   Created:      2018-01-15  21:24:35 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1466368 Bytes = 1.4 MiB
   Load Address: 01200000
   Entry Point:  01600000
Programing start at: 0x01200000
write : 100%
done
## Checking Image at 02166080 ...
   Legacy image found
   Image Name:   user
   Created:      2018-01-15  21:24:54 UTC
   Data Size:    15958016 Bytes = 15
