This is what I observed with flashing IRs on HFW3200C including band aid fix:
Removed camera to work bench. Reconnected to POE switch and observed flashing IRs when lights were turned down. Noticed flashing rate changed in relation to ambient (now dim) lighting. Unscrewed glass end cap, flashing immediately stopped. Was able to re-start flashing by holding a white envelope ~6-8" in front of now exposed camera and IR set. Flash rate changed depending on how I held envelope. Decided these observations were not consistant with some sort of short circuit as some have speculated. Observations were consistant with circuitry of light sensor U1 being improperly affected by illuminated IR string. Could be due to aging of components. Likely involves near complete loss of hysteresis. Dahua engineering should have analyzed this by now. My band aid fixed for this is to place a small shield around U1 light sensor. Made one out of the cut-off end of a 14 ga. crimpable butt splice. Tough plastic, cut with X-acto. Glued it on pcb (around U1) with contact cement. Used tooth pick to transfer/apply cement. So far this shielding of U1 has stopped the flashing IRs on my HFW3200C. There was actually no need to dismount the camera.
