- May 18, 2014
- 46
- 4
Ah, so you think it's maybe a ground issue, that would make sense.
It makes little sense to me because it didn't happen out of the box (as you would expect a ground issue would), but showed up slowly, one camera at a time until half the cameras I bought had the problem. MAYBE it's an issue where a resistor helped keep the problem from manifesting, but eventually wore down and completed the circuit (short) and the blinking started. Whatever the case. Isolating with electrical tape, while crude, completely fixes the issue. When I get time (maybe never?) I'll work on it some more and maybe get a more elegant solution that allows the screws to be put back in.
