Can't use sub streams?
cmx
Nov 9, 2024
125
51
NJ
I have 6 identical cameras out of the 6 only one of them will let me use the sub stream! All 6 have sub stream turned on all use the same ports, settings, firmware, codec.
But BI using the latest version will not find the substreams on the other 5, i even tired to clone the working cameras settings and then i would just not get video.
The correct video path is
/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
if i use that on one of the other 5 i get no video.
FWIW, the URL you posted is for main stream (subtype=0).
When you say ".... All 6 have sub stream turned on...." does that mean you've logged into each camera's webGUI and enabled/configured the sub stream?
EDIT: Are you using "Find/Inspect" to populate the BI video configuration boxes?
Yes find and inspect leaves it blank, Yes all had the sub stream on by default but i did log in and check.
even if i put /cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
The other 5 will not show any video unless it's left blank.
Reactions: TonyR
All 5 are the same.
Device Model
IPC-Color4K-T180
Audio Input
1
Audio Output
1
Alarm-in Port
1
Alarm-out Port
1
ONVIF Version
24.12(V3.1.0.2313712)
System Version
V3.140.0000000.81.R, Build Date: 2026-05-08
Web Version
V5.01.0.2447661
Algorithm Version
V6.02.09.0
Security Baseline Version
V2.4
H5Player Version
V3.01.1
Copyright 2026, all rights reserved.
Goto whatever page/link the camera provides for Users / Accounts.
Select the tab that says Onvif.
Be certain whatever user you're putting in Blue Iris username has a matching Onvif user defined.
It is i use admin for them all. Even though you shouldn't.
