Hi
I have a few cameras on a remote connection using a vpn. I can connect to local cameras using BI no problem
However, trying to connect to a Hikvision camera (1 of many) on the VPN does not work. The port number is essential as using iVMS I have to explicitly insert a port number in the config to view the camera (it works) ,how to do same on BI please ?
Thanks
Thanks
