tangent
- May 12, 2016
- 4,641
- 3,996
So we're on the same page: the camera and mic psu are both located in your basement and the mic is powered via Ethernet cable?@tangent, I now have read the entire thread and your recommendations. Unfortunately I didn't before installing my mics and I wish I did. I would have taken precautions to minimize the ground loop.
So, the cam is an SD59225. It is powered by a mid-span plugged in 20 feet from the mics power supply. I ran two ethernet cables from the basement, up though a future tube to the attic, across the entire length of the house and out the soffit to the cam in the far corner. As the cables exit the tube in the ceiling of the basement, the mic power goes to the nearest double gang about 5 feet away. I used the twisted pair of orange and brown for the 12v + and -. The data/power ethernet cable to the camera continues along the floor joists above to the mid-span across the room. I'm going to say it's plugged in to a different 15 amp circuit that is run in my basement.
Another strange thing is it comes and goes as well. Sometimes there isn't any Sunny 107.9 playing. Weird.
SD
How far are the camera and microphone from one another? What type of cable did you run between them for the audio signal?
Changes in the atmosphere effect radio signal propagation. Assuming that's a SUNY station, I could see more variation in their broadcast than your average radio station... I suspect it might also be broadcast on AM.
